Author Topic: Removing head with engine in.  (Read 7571 times)
Offline onethumb
Re: Removing head with engine in.
« Reply #15 on: February 19, 2017, 09:48:03 AM »
Bryan and trigger I'm one of those people
« Reply #16 on: February 19, 2017, 10:56:06 AM »
You are right Trigger, but on the tin it sez Grinding paste usually coarse at one end and fine at the other
« Reply #17 on: February 19, 2017, 09:49:04 PM »
Mine definitely says Lapping paste  ;) Should I be using Grinding paste Bryan ?
Offline archmill
« Reply #18 on: February 19, 2017, 10:59:40 PM »
Bought valves, valve retainer plates, guides and stem seals from cyclex in USA for £260. Adding postage, VAT and auntie Teressa's cut ( import duty ) came to £350. The valve retainer plates are to stop the valve collets pulling through, which is exactly what happened before I got the bike
Offline archmill
« Reply #19 on: February 19, 2017, 11:02:34 PM »
P.S. you can't remove the head with the engine in place. I made and fitted a frame kit which allows you to remove a section of frame, them you can remove the head and cylinders.
« Reply #20 on: February 20, 2017, 06:16:21 AM »
Thats cos you got new stuff Trig, mines from the 70's still
Offline onethumb
« Reply #21 on: February 20, 2017, 03:16:19 PM »
Trigger thanks for the info. I spoke to Barry this morning,(he knows his onions!) I'll be getting it to him as soon as I've stripped the whole bike down again and removed the head.
Thanks again.
Steve.
« Reply #22 on: February 20, 2017, 07:14:24 PM »
Thanks again.
Steve.
Sorry I could not sort you out but, only if you wanted to join the waiting list.
Have you done a compression test yet ?
Offline onethumb
« Reply #23 on: February 20, 2017, 08:39:39 PM »
Hey no worries thanks for the info and the contact.
Not done the test yet I'm away from the bike this week so I'll test it next week on the kick start then I'll remove it from the frame ready to strip.
Anything I should look for that might show up something other than a head issue?
