Author Topic: Engine  (Read 2311 times)
Offline Parobbo13
Engine
« on: March 02, 2017, 11:14:00 AM »
I have a 1977 CB750 F1 model when you use the kickstart it only turns the engine so far then stops solid but if I take the points cover of I can put a spanner on the end of the crank where the eng will turn backwards quite easily but then stops again. It will turn both backwards then forwards about 270 degrees.
The eng will turn over easily between these two points but no further.
Are these engs prone to this if so what is the problem?
Am just in the process of getting the eng out then strip it down until I find the fault.
Checking on her to see if anyone has the same problem &/or any ideas as to what it might be.
Thanks in advance.
Re: Engine
« Reply #1 on: March 02, 2017, 11:15:33 AM »
Sounds like you have a valve stuck open or possible worse. Only way to check properly is strip it...
Re: Engine
« Reply #2 on: March 02, 2017, 01:36:22 PM »
Take the rocker cover off and see if the valves are behaving themselves.  It could be the valve timing -check if the timing marks line up, as per the manual.
Re: Engine
« Reply #3 on: March 02, 2017, 01:50:10 PM »
Will it turn with the plugs out? Worth a check, as if you have a flooding carb you could be trying to compress a cylinder full of petrol, and if you continue trying you may cause serious damage. Engine needs to come out before you can remove the rocker cover.
Re: Engine
« Reply #4 on: March 02, 2017, 03:10:32 PM »
A sticky valve like this James  ;D ;D
Re: Engine
« Reply #5 on: March 02, 2017, 03:58:54 PM »
OUCH!
Re: Engine
« Reply #6 on: March 02, 2017, 04:22:11 PM »
Ha ha, wondered when that would surface. Is that from my 'one careful owner' K0 engine?
Re: Engine
« Reply #7 on: March 02, 2017, 07:20:21 PM »
Nope, this is from a K4 with K2 top end, which was re-bored, new piston and rings fitted, then left on the side stand for years in a dry USA state  ;) Had it set fire to it, to get the thing apart.
Offline Parobbo13
Re: Engine
« Reply #8 on: March 04, 2017, 10:14:54 AM »
Thanks for your replies, the next job is to take the engine out then start to strip from the top, looking for the fault as I do it. Hopefully get to the fault pretty soon then re-assemble to get back on the road.
