Author Topic: Anatomy of a 400/4 Horn (also CB250/360 G5)  (Read 16941 times)
  • Moderator
« on: June 23, 2017, 08:24:56 AM »
Promised that I will look at fixing a 400/4 style horn to go with a bike I am selling.
The pictured one was a dead as a dodo .. I totally sealed it up in 1986 and then nickel plated it hoping the electrolyte didn't get inside. Fast forward many years it doesn't work any more  so, fearing  the worst, I therefore  decided to open up after bead blasting and take a peek inside with a view to fixing it.. No real corrosion but contacts oxidised so had to move springy contact bar over to gain proper access to clean contacts. You have to de-crimp the outer (mild steel ) ring to gain access. i didn't make a particularly neat job but it will tidy up OK. The coils seem to be mega reliable so don't burn out in my experience
Busy at 'mo but I will do a write up when I have time on how to totally disassemble for replating in zinc.
Would be a nice sideline for Kent400 !!!!
Meanwhile a couple on annotated pics:-
« Last Edit: June 23, 2017, 08:26:52 AM by AshimotoK0 »
Offline andut
  • CB400F, CB400F Cafe & NC30
Re: Anatomy of a 400/4 Horn (also CB250/360 G5)
« Reply #1 on: June 24, 2017, 09:54:34 AM »
Excellent timing Ash !
I keep looking at my project 400's horn and wondering if it's salvageable, so your 'how to dismantle' write up would be very useful - I've not even managed to remove the plastic cover yet as it seems very brittle and likely to crack as soon as I start to lever it off ! A guide and any tips would be most welcome !
Andy
  • Moderator
« Reply #2 on: June 27, 2017, 08:13:41 AM »
Well ...if you look here these are interesting. The Honda Shadow horn internals are basically identical to the 400/4 horn.
https://www.youtube.com/watch?v=rJV2iu3BzmY
https://www.youtube.com/watch?v=iDUgnvlvXpo
In the disassembly video clip, he mentions that it's almost impossible to get at the points to clean them but I found a way around that. If you look in my photo's I moved the main contact bar away from the other 'springy'  contact bar by lifting it slightly and rotating so that the contact is visible through the large threaded hole in the centre. You now have access to clean both contacts properly and then carefully reposition the contact bar so that  both contacts are aligned.
Detains on 'tuning' it will follow. Re-crimping is harder to do than on Honda gauges (speeedo/tacho) but it is possible to do a neat job with a bit or care and patience. Another method of contact access (and also if you wish to re-plate the horn) is to drill out the copper rivet that retains the contact bar and either find a replacement copper rivet or use a brass or copper   nut and bolt,   if you are not too fussed about originality.
One of the two YouTube video clips shows drilling of a hole to inject contact cleaner at the correct spot inside the horn. Mine had pretty tough to remove oxidation on the points but the method may work, as once you get current to flow and the horn oscillates, the highly inductive load's back EMF arcs across the contacts and the contact erosion effectively self cleans them (just like ignition contact breaker points). my main reason for learning to disassemble these horns was to enable me to fully zinc plate the  steel parts for my 400/4.
Perhaps we should ask Ozzy Osborne how to adjust the horn after re-assembly as that was his job at Lucas in Birmingham  :) . It's basically  a case of adjusting the large finely threaded pole piece / nut by screwing in and out  to give maximum armature force and correct movement and then adjusting the M4 screw/locking nut to achieve oscillation by making and breaking of the contacts.
The black plastic cover does get brittle. Best bet it to get it as hot as possible, without melting it  and insert a thick knife blade and gradually prise it off.
« Last Edit: June 28, 2017, 07:42:00 AM by AshimotoK0 »
  • Moderator
« Reply #3 on: October 19, 2023, 10:56:12 PM »
I brought a totally original but dead 400F horn to life today for my own 400 using  a Honda-4  ignition coil. I was originally going to de-crimp it to clean up the points inside but with this method it's non-invasive.
Trick is to connect both HT cables of the ignition coil to the the horn terminals. Connect the black/white wire of coil to a 12v battery and clamp the tang of a coarse file onto the negative terminal of the battery. Connect a piece of wire to the other terminal of the horn  (blue or yellow wire depending on which side coil) and strip the other end back about 10mm and twist the copper strands together. Then repeatedly brush the wire against the file teeth so that you create lots of makes and breaks of the current through the primary of the coil and correspondingly  lots of HT pulses are generated on the HT leads, which discharge through the oxide layer inside the points of the horn. This repeated action soon breaks though the layer of insulating oxide on the horn points, so that conduction is soon restored. You then disconnect the HT leads and test for current flowing through the horn again. If not reconnect the HT setup and keep trying. Ideally you would also connect a points condenser between the battery negative and the coil wire to give a better build up of HT but in my case it wasn't required.
« Reply #4 on: October 20, 2023, 12:36:23 AM »
Interesting process Ash especially the coil connecting- nothing like as complicated but I have revived old car horns for a short period by connecting one side to the negative side of a fully charged 12 v battery then rapidly connecting & disconnecting the live terminal so it progresses from a dull click to eventually making the horn sound. Only seemed to work for a short period on a seldom used car horn. I thought it was due to the back EMF somehow reviving the contacts.
« Last Edit: October 20, 2023, 12:53:16 AM by McCabe-Thiele (Ted) »
  • Moderator
« Reply #5 on: October 20, 2023, 07:34:03 AM »
Different problem Ted. On these Mitsuba horns, when not used for 30 odd years, they  develop a hard, totally non-conductive, oxide layer and in this case will not pass any current at all at 12v. You need a very high voltage to discharge through the oxide layer to 'puncture' it repeatedly. If you look back at the beginning of this post, there are other methods but this is my 'go-to' method in the future. Wonder if it will work with open circuit oil pressure and hydraulic brake switches?
Offline Rozabikes Tim
« Reply #6 on: October 20, 2023, 07:51:57 AM »
You are a wizard Ash.
  • Moderator
« Reply #7 on: May 28, 2024, 11:17:44 PM »
Update on this.
I found a couple of Honda CB400F style Genuine horns in my stash  the other day that were totally dead. My rig to inject EHT to arc across the contacts in order to revive them....  as described on here previously ...  was at work. So I tried removing the M4 adjuster screw/lock-nut completely and with 12v connected across the terminals I repeatedly pushed down inside the hole with a thin crosshead screwdriver to physically move the contacts apart and together again. After quite a few makes and breaks there was eventually a bit of a squeak and the horn started to conduct current, so I carried on making and breaking the contacts and the current gradually increased until the horn worked perfectly, after adjusting the large centre screw and the M4 'tuning' screw. Worked on both horns eventually and worth a try if you have dead horns.
  • Moderator
« Reply #8 on: June 07, 2024, 07:50:38 PM »
Managed to zinc plate my 400F horn without de-crimping ( pressurised it first and immersed under water whilst still under pressure in order to check it was totally sealed.......which it was and so were the other two horns I had.
This horn was a rusting hulk before I restored it and completely dead electrically (see above). Quite pleased with it now and genuine decent ones are £££'s now, if you can find one....so I guess it was well worth the effort.
« Last Edit: June 07, 2024, 11:21:43 PM by AshimotoK0 »
« Reply #9 on: June 07, 2024, 07:54:44 PM »
Better than new! 👍
« Reply #10 on: June 07, 2024, 08:35:49 PM »
Serious bling going on there Ash 8).
I used your method to repair my old rusty item and it 100% worked. The de-crimping was the difficult part, or trying to hold it was anyway.
  • Moderator
« Reply #11 on: June 07, 2024, 11:19:29 PM »
The one I de-crimped , I fitted to the CB250G5 project I sold a few years back Dave. Since then,  I have established that the horns are watertight  ( so can be plated as a complete unit) and can be revived electrically if it's just the points that have oxidised, without the need to de-crimp. As you say they are very tricky to de-crimp and re-crimp.
Offline ozzybud
« Reply #12 on: June 07, 2024, 11:39:00 PM »
I just received this unit from Japan. Mt Fuji on US EBAY was the seller. spot on to the original and beautiful.
I got it for way less than his asking price
This was for my new 400 . I have been looking a long time for an NOS one Or a Gem like this for my CB360T.
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
  • Moderator
« Reply #13 on: June 08, 2024, 07:32:07 AM »
Wow ! I knew they were expensive .. but not that expensive ! Being a picky Anorak .... which I unashamedly am  :-[ :-[  ... this is Anoraks Corner after all  ;D..... The stampings, plastic terminal mounting and centre thread are not the same as the original 400F/CB250/360G5. Plastic cover looks good though for a repro.
Need to refurb my other two now !
« Last Edit: June 08, 2024, 07:39:31 AM by AshimotoK0 »
« Reply #14 on: June 08, 2024, 09:47:53 AM »
Wow, that price is eye watering  :o. Just shows how expensive these individual parts are becoming and why it is difficult to justify restoring a bike to original spec and then of course you have to ask yourself the question 'If I have spent all this money restoring it should I ride it and ruin it'. This is why I'm trying to restore Ratty back to stock but have no problem using stainless fasteners where I can for practical reasons. I do however remove the stampings from the bolt heads and polish them to give a decent finish.
