CB750
Camshaft troubles
Topic: Camshaft troubles (Read 6439 times)
SandwichEnthusiast
Camshaft troubles
October 06, 2007, 04:57:57 AM »
So I've taken the reins on a project 1975 CB750, which in my inexpert opinion seems in pretty good shape, and I'm hoping I can get it back into action for next season.
We popped the Cylinder head cover off, and the camshaft has broken under the third holder from the left, and kinda gored the holder up.
So it looks like I'm in for a new camshaft and a new camshaft holder.
So I'm looking for some sagely advice;
http://www.crotchrocket.com
is giving me a about $113 for a holder and $228 for a new camshaft (I don't even know where those parts are coming from)
Should I be assuming I need 2 new camshaft holders?
what does this mean for the rest of the engine? Is there going to be damage all the way through?
What did the previous owner do to screw it up like this?
I'm kinda resting on my laurels to clean out the garage to get some space to rip this bike apart, and am waiting to find out what this camshaft damage means I'm in for. Any advice/comments would be appreciated. Thanks.
BTW I'm in Canada, but this seems like a good CB fourm.
Dave M
SOHC Expert
Re: Camshaft troubles
October 06, 2007, 08:36:00 AM »
If the cmshaft snapped then you could also be looking at valve/piston damage if a piston has hit a valve.
I'm not sure if there's any clearance between an open valve and the psitons but I'm sure our experts will be able to offer some additional advice.
Dave
Melbourne.
BassMan_720
Newbie
October 06, 2007, 09:21:54 AM »
It's head off time, I'm afraid. An open valve will clout the top of the piston.
You should be able to replace only the damaged holder. These were supplied separately by Honda. Cam oiling was a weakness in early CB750s. I thought that they had sorted this by 1975 though.
I trashed a camshaft back in 1977. I traced a problem down to a blockage (suspected fibre from the paper oil filter) in the small metered hole in the head that feeds the holder oil way. This didn't snap the camshaft but it didn't do it or the holder any good at all.
Several of my mates (we all had CB750 at the time) with K0-K2s also had similar top end problems. I don't recall any of my mates with F1s having this problem. If you search through the CB750 forums you will find plenty of advice about regular oil changes to avoid this in future.
Fingers crossed that the damage is minimal. These parts are quite scarce. After a failed search over here, I've recently won similar items on eBay, from the states, for my restoration project.
Good luck
Steve
CB750K2 1972
Guzzi La Mans II 1980
Rpyan Enfield G 1948
JonnyB
Repeat: It's only a Hobby, It's only a Hobby....
October 07, 2007, 09:44:57 AM »
I had to rebuild a couple of years a ago, on My F1 ('76) I had a "squealer!!" The cam had seized in the holder due to oil starvation. When I dropped the oil filter there was so much metal in it the oil looked like silver paint.
I've had two cams fail though oil starvation and I once bought an engine for spares and it had the same problem, but I've never seen a snapped camshaft, I'd like to see a pic of that.
To do the job properly and still have faith in the engine afterward, you really need to get a camshaft AND cam carriers from the same engine, you'll know then that the wear will be even.
I would, (and did) do a complete engine strip, and took the oppertunaty to check all the other bearings and clean the crank cases of any dirt.
As Steve said check the piston crowns, and valves for damage, a new pistons are around but cam holders and caps are a rare as rocking horse sh*t.
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
Basket Case - K100/1200 hybrid
John
https://batchscan.co.uk/
SandwichEnthusiast
October 13, 2007, 05:32:37 AM »
Thanks for the information. I've been assuming I'd need to tear down the whole thing, at least to look at it.
Somebody mentioned wanting some photos, and I have a bunch up at:
http://www.uoguelph.ca/~ibaran/
sorry for the low budget directory list,
DSC00066.JPG, DSC00068.JPG, DSC00070.JPG is the broken side,
and
DSC00067.JPG is the good side (im a little nervous about that wear in the center, should I be?) and DSC00065.JPG is the whole top end.
Anyone who would like to roll through them all and give me any comments on condition, or anything else for that matter I would really appreciate it.
could it have been as simple as overtourqing the camshaft holder?
Spitfire
October 14, 2007, 01:45:36 PM »
Yep, seen that before quite a few times, head off check for bent valves, clean out all the oilways, I always used to replace the cam towers as pairs but they are getting hard to find and expensive these days so give the remaining one a good check over before re using it. Check the pistons and rings as well, the middle cylinders tend to suffer from nipped up rings, had that on my K1 and my current F1. Check the oil pump screen for bits of metal as well, when rebuilding I only use genuine Honda head gaskets, I also only use a good quality oil and change it every 2 thousand miles and the filter every 4 thousand. Make sure also that you lay out all the parts in the order that you removed them so they go back in the same place that they came from. Cleanliness is next to godliness when rebuilding as those oil holes are mighty small.
Den
CB750
Camshaft troubles
