Author Topic: 550K0 restoration  (Read 2912 times)
Offline dv11250
550K0 restoration
« on: March 28, 2019, 11:21:47 PM »
 Bought the CB550K0 three weeks ago, US model bought from England with a seized engine.
Having raced karts for 15 years I thought an seized engine rebuild would be fairly easy.
So bike stripped down to the frame in 2 days.
Rocker cover off to discover that one the cam gear screws was down inside the head channel. no option but to split the cam chain and order a new link.
head off and inside pistons are at the top and outside pistons bottom. no movement in the crank at all. :'(
Only 1mm on inside bores to fill with release fluids
soaked in parrifin for three days - no movement.
soaked in Diesel for three days still no movement - applied 2 heat guns until the diesel was bubbling - still stuck
soaked in Liqid-Moly penetrating oil and TQF and heated every night for 10 days.
last night got 0.5mm movement by rocking barrels front to back with a large screwdriver under the fins ay the rear and a 5mm steel plate under the front fins at the two raised points on the front of the crankcase.
Tonight same rocking again while my son tapped the pistons gently with a wooden block and hammer.
30 mins later barrels off - 2 x small ends tight.
 next session tomorrow night
Re: 550K0 restoration
« Reply #1 on: March 29, 2019, 08:15:53 AM »
You are going to be splitting the cases on that one so just fit new cam chain not link. Would suggest new primary as well.
Offline dv11250
« Reply #2 on: April 04, 2019, 08:17:14 PM »
Thanks Bryan for the advice on the chains
just working out what all i need for the engine/bike rebuild on get order placed with DS (unless there is anywhere else to get bits).
Got the engine stripped down completley.
Could someone advise what this is screwed into the bottom of the crankcase towards the rotor side
« Reply #3 on: April 04, 2019, 08:23:33 PM »
It direct a bit of oil to the primary chain, should be two things screwed in leave them there.
Primary damper rubbers are a good idea inside the primary driven gear where starter gear is.
« Reply #4 on: April 04, 2019, 11:29:31 PM »
Good advice Oddjob. Am I correct to assume the same also applies to the big end shells?
1976 Honda 400/4
Offline dv11250
« Reply #5 on: May 23, 2019, 06:27:12 PM »
Piston rings arrived this morning from Cruzinimage.
Could someone advise the order they are fitted.
I know the oil ring is in the bottom slot.
The other two rings are black and silver with STD marked on them.
« Reply #6 on: May 23, 2019, 07:50:33 PM »
Top ring is silver, 2nd ring down is black.
Like so.....this is a CB400/4 Cruzinimage piston/ ring kit [ Guests cannot view attachments ]
« Last Edit: May 23, 2019, 07:52:58 PM by Nurse Julie »
« Reply #7 on: May 23, 2019, 10:33:41 PM »
With any markings facing upwards.
Offline dv11250
« Reply #8 on: May 23, 2019, 11:19:40 PM »
Thanks Bryan and Julie,
Rings fitted, new gudgeon pins and circlips, and barrel onto engine.
starting to look like a bike again
Offline dv11250
« Reply #9 on: May 23, 2019, 11:22:34 PM »
Can any one advise what the 8 green o-rings in the NE gasket set are for.
dont remember taking any off when I stripped the engine
« Reply #10 on: May 23, 2019, 11:28:20 PM »
They are silicone O rings for under the valve guides.
Offline paulbaker1954
« Reply #11 on: May 24, 2019, 02:08:55 PM »
Looking nice - out of curiosity whats the red thing at back of garage
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline dv11250
« Reply #12 on: May 24, 2019, 02:36:53 PM »
Countax lawnmower
« Reply #13 on: May 24, 2019, 03:56:36 PM »
How big is your lawn  :o
Offline dv11250
« Reply #14 on: May 24, 2019, 05:15:15 PM »
Takes over an hour to cut with the tractor lawnmower, never mind doing the edges.
