CB750
Info
Topic: Info (Read 3496 times)
Seamus
Info
March 28, 2020, 09:06:19 AM »
Been trawling through my backup disc to see what could be deleted.
I have a description of how to make a float height check tool for a cb750 and an article on twin disc conversion. Not sure if its for a 500 or a 750. Originally by a chap called Ben Hiles, and probably from the US site. If they are of any interest, I will post them.
Re: Info
March 28, 2020, 09:26:44 AM »
I think i have seen the twin disc article and it has a BIG error in that it tells you to use a 500 speedo drive which is not accurate
Seamus
Re: Info
March 28, 2020, 11:20:47 AM »
Yes, I seem to recall that now that you have commented. Worth posting??
Re: Info
March 28, 2020, 02:21:10 PM »
All info can be usefull as long as you read it assuming there are faults!!
Seamus
Re: Info
March 30, 2020, 08:48:31 AM »
Atached diagram of float height tool for CB750. Cannot remember where it came from as I found it when I restored a 750 K1 a few years back.
Seamus
Re: Info
March 30, 2020, 08:51:57 AM »
Dual disc modification. Authored by Ben Hiles. Think it originated from the US site.
There is an error relating to the use of a cb 500 speedo drive, as pointed out by Bryanj
May give some pointers though.
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
Re: Info
March 30, 2020, 09:39:39 AM »
Could someone edit it with the correct info and I’ll put it in Aladdin’s Cave.
I can’t as I don’t know what’s incorrect
Arch stanton
SOHC Expert
Re: Info
March 30, 2020, 12:48:32 PM »
Excuse me for jumping in but.
I do find it a little odd. That honda put mounting holes etc on the fork opposite the disc. But then to fit the second disc.
Involved a lot of messing about with spacings. I'd have thought. All that was needed was the same parts only reversed. Like on the later F1.
Re: Info
March 30, 2020, 05:07:34 PM »
They probably saved a few yen per leg by not having them machined
Re: Info
March 30, 2020, 05:22:52 PM »
Steve, hopfully attached with an EDIT at the end. Please read it and see if it makes sense to you as i ,hopfuly, know what i mean to say but things dont always read as you mean it.
Arch stanton
SOHC Expert
Re: Info
Reply #10 on:
March 30, 2020, 05:46:14 PM »
Could have saved more Yen. By not having the facility at all.
Just seems odd. Doing half a job.
SteveD CB500K0
Administrator
Re: Info
Reply #11 on:
March 30, 2020, 09:05:00 PM »
Both these files available in Aladdin's Cave (SOHC General folder)
CB750
Info
