Author Topic: 550F Silencer  (Read 5778 times)
Offline Oggie400F
550F Silencer
« on: May 12, 2020, 09:28:36 AM »
Does anyone have recommendations for a replacement silencer or, if needed, a full system for a 550F that is not too loud.
The silencer that came with my Café Racer is a cut down straight through and, even after fitting a baffle, is far too loud for me.
Also I have measured the OD of the collector box outlet pipe at 56mm so am struggling to find a 'slip on' large enough to fit. Is this the correct size for the original header and collector box, they look original?
Re: 550F Silencer
« Reply #1 on: May 12, 2020, 09:52:18 AM »
56mm sounds about right as, the silencer is 60mm ID and there is the gasket. I have a silencer that I was going to put up forsale.
A motad in Stainless is a good replacement, if you can find one  ;)
Offline Oggie400F
Re: 550F Silencer
« Reply #2 on: May 12, 2020, 10:57:02 AM »
Cheers Graham
Is the one for sale on original?
Either way I'm interested as if it's original I would like it just in case I return the bike to stock spec.
Offline cooleronthecoast
Re: 550F Silencer
« Reply #3 on: May 12, 2020, 12:54:22 PM »
Good luck with finding an original Oggy. I've seen more Unicorn turds recently!   Lol.   I have a 550 Motad system in the shed (I'll see if I can get a photo posted up here or if you give me your email I'll send you one if you are interested).  Its in reasonable shape but I ended up buying a Delkevic stainless system for mine so the Motad is surplus to requirements.
Now where did I put that 10mm socket?
Offline Oggie400F
Re: 550F Silencer
« Reply #4 on: May 12, 2020, 01:18:27 PM »
I've looked at the Delkevic system but wasn't sure how they sound.
Is yours the straight or megaphone silencer and is it loud?
If you can post a photo of the Motad I may be interested.
Mind you, if Trigger sells me his for 99p I won't need it! 🤣🤣🤣
Re: 550F Silencer
« Reply #5 on: May 12, 2020, 02:15:17 PM »
My Delkevic is the straight system and yes, it is loud.  Strange isn't it?  When I was a kid I'd have junked the original system and put on something like the Delkevic in a flash.  Now like you. I prefer something more original and quieter.   I must be an old fart!   ;) [ Guests cannot view attachments ]
Here's the Motad, the picture flatters it to be honest, it would need work if you were to fit it, but could be made nice with effort.   I see you are just down the road in Hull, so if you fancy a detailed look you are welcome to pop up. Now the lockdown rules have been relaxed. I live just a few miles North of Brid off the A165.
« Last Edit: May 12, 2020, 02:22:42 PM by cooleronthecoast »
Re: 550F Silencer
« Reply #6 on: May 12, 2020, 02:40:44 PM »
Is the silencer on that motad good ? I think I have a motad somewhere that has good down pipes but, the silencer is shot.
I will be passing Hull tomorrow so, it looks like everyone is Hull side  ;)
Re: 550F Silencer
« Reply #7 on: May 12, 2020, 02:53:10 PM »
On the whole yes, the main body is very good however where the down pipes fit in there is some corrosion I've tried to photograph this below:
Re: 550F Silencer
« Reply #8 on: May 12, 2020, 03:19:24 PM »
Corrosion ? That looks more like a hole or is it just black in that area ?
Offline Moorey
Re: 550F Silencer
« Reply #9 on: May 12, 2020, 03:53:40 PM »
The hole is free it comes with the corrosion.  ;)
Re: 550F Silencer
« Reply #10 on: May 12, 2020, 04:52:55 PM »
Its a miniature Bat.   ;)
Re: 550F Silencer
« Reply #11 on: May 12, 2020, 06:46:39 PM »
Ian, yes, it's an original silencer and I have just PM'd you some pics.
Offline Oggie400F
Re: 550F Silencer
« Reply #12 on: May 12, 2020, 10:43:42 PM »
Thanks Julie
I have replied to your PM. 👍
