Author Topic: Honda Cb400f Rebuild  (Read 5588 times)
Offline Dylaxn
« on: May 07, 2021, 08:27:13 AM »
Hey!
I have recently inherited a CB400F from my Father-in-Law which looks almost complete. As far as I know, the engine has been fully rebuilt with a new loom too.
By the looks of things, it looks a case of attaching the front light, fitting the petrol tank, attaching the fuel lines, seat and other little bits.
I will try and do most of the work with the help of the Haynes manual and Google, but are there any specialist garages that can thoroughly check it over to make sure everything is done correctly ect.
Re: Honda Cb400f Rebuild
« Reply #1 on: May 07, 2021, 09:24:53 AM »
Download the proper Honda maual and use the Haynes to light the barbie
Offline smoothoperator
« Reply #2 on: May 07, 2021, 09:25:39 AM »
I wouldn't worry about getting it checked over by a garage just yet, just systematically work through the jobs you have identified with the first aim being to get it running. There will be lots of little challenges along the way, just keep posting when you hit a snag and you'll get plenty of advice and learn as you go along. Nice to have a 400 restore in my neck of the woods, I live in Peterborough.
Steve
2017 Triumph Bonneville T100
« Reply #3 on: May 07, 2021, 11:11:48 AM »
Hopefully the carbs have been properly cleaned and rebuilt as it's these that give 90% of the starting/running problems. Do you have any history of the work undertaken and bills for spares used?
Any problems though just post a question and you will get a response almost straight away.
« Reply #4 on: May 07, 2021, 11:15:21 AM »
And a good tip............if you strike a problem go to the 400 Four section of the forum and use the search box on the upper r/h side to type in the issue you have, most 400/4 questions have been asked at some point  :)
Offline Dylaxn
« Reply #5 on: May 09, 2021, 11:25:55 AM »
Hey,
First hurdle..
I'm putting in the engine mount bolts but noticed a big gap on the top one between the engine and the frame. Is there supposed to be a washer / spacer there?
Unable to attach photo due to size..?
Offline Deano400
« Reply #6 on: May 09, 2021, 11:41:48 AM »
Do you mean this gap? If so yes you should have a spacer.
If you can't find it let me know and I'll measure one for you so you can have one made. Unless someone has a spare one.
Offline Dylaxn
« Reply #7 on: May 09, 2021, 11:43:41 AM »
(Attachment Link)
That's exactly it! I haven't a clue where it is so if anyone has a spare or I can get one made, that would be really helpful.  :)
Offline Deano400
« Reply #8 on: May 09, 2021, 12:02:00 PM »
I.D. = 10.6mm
O.D. = 24.0mm
L = 12.6mm
amx1992
« Reply #9 on: May 09, 2021, 12:08:57 PM »
Id be happy to make you a stainless one tomorrow for the price of rhe postage. Pm me if you want
Offline Dylaxn
« Reply #10 on: May 09, 2021, 01:03:21 PM »
I've just messaged you, thanks so much!
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #11 on: May 09, 2021, 03:51:54 PM »
Hello and welcome to this wonderful forum,
If you are on with engine bolts, be careful with the two lower ones at the front of the engine, through the frame rails - they should be slightly different lengths, the shorter one going on the left hand side.  This prevents it from possibly puncturing the oil gallery, which has happened.  There's only a couple of mm difference.  If you look right underneath when fitting the bolts and the end of the left hand one starts getting really close to the casing - don't go any further, something's wrong.
Ian
« Last Edit: May 09, 2021, 05:55:16 PM by orcadian »
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Offline Dylaxn
« Reply #12 on: May 09, 2021, 07:21:30 PM »
Thank you.
Looking through the parts lists, It's 50329-286-010
Offline Deano400
« Reply #13 on: May 09, 2021, 08:12:50 PM »
Thank you.
Yes that is correct for the spacer.
Offline Deano400
« Reply #14 on: May 09, 2021, 08:19:43 PM »
Ian, do you know where the info that the lower hanger bolts are different lengths comes from? I've read other posts that say the same, but the parts book gives the same part number for both the left and right hanger. My understanding is that they are both M10x74.
Dylaxn, the other critical thing about the installation of the two hanger bolts apart from the length, is that the spring washer must be installed at the head end of the bolt.
