Project Board
The rebirth of Lazarus
8
9
10
11
29
Topic: The rebirth of Lazarus (Read 217927 times)
Laverdaroo
Re: The rebirth of Lazarus
Reply #120 on:
October 22, 2022, 05:13:09 PM »
and if he doesnt want it, I'll have it, that looks much nicerthan the standard affair tbh.
Sesman
Reply #121 on:
October 22, 2022, 05:20:20 PM »
I’m in the queue too. Oddjob might not survive his first ladyboy sled ride and Roo is dealing with crocs (not the popular footwear).
Sesman
Reply #122 on:
October 22, 2022, 05:21:03 PM »
Or are they gators?
Oddjob
Reply #123 on:
October 22, 2022, 05:22:03 PM »
Twowheelspares has a 650 cover for sale on Ebay, it's got some slight damage but nothing that won't polish out IMO. There's a NOS in Italy but it's around £100 including P&P.
Laverdaroo
Reply #124 on:
October 22, 2022, 05:30:27 PM »
Gators dear, they're emuch mre sofisticated I mean, middle class than mere crocodiles I'll have you know.
The chap who helps oout here had a personal best here last week...............8'6"...Yikes, thats quite a beast!
No pictures sadly!
mickwinf
Reply #125 on:
November 05, 2022, 02:55:14 PM »
A little progress with Lazarus, i now have a complete correct airbox thanks to Gary, all cleaned and polished with new air filter and spring. Also have the little rubber seal that fits at the front of filter holder and the tool tray etc. Will need a new gauze for the intake but i think Julie sells them, also if anyone has the little flat spacer washer thingy that goes between the filter box and manifold i need one to be correct. Engine is almost complete, i have just fitted an oil pressure switch but unsure if it needs any thread sealer or is it self sealing?
Reply #126 on:
November 05, 2022, 04:33:34 PM »
Its a taper thread so the theory is no sealant but a turn or two of ptre tape wont hurt
mickwinf
Reply #127 on:
January 01, 2023, 03:49:33 PM »
Engine now finished and painted and polished, can go to one side until rebuild time. As a bit of a change i have started to work on the front forks. One lower has been polished up and fitted with new seal and re-united with a re-chromed stanchion but i have a question about the fitment. My forks are the early type with the rod up the middle which screws into the top nut, with a lock nut under. My question is, how should it be adjusted?
Oddjob
Reply #128 on:
January 01, 2023, 06:30:40 PM »
Screw the rod into the top nut until it won't go any further and lock it with the locknut. IIRC.
mickwinf
Reply #129 on:
January 02, 2023, 04:39:04 PM »
thanks Ken that makes sense
mickwinf
Reply #130 on:
February 25, 2023, 09:16:02 AM »
An update on Lazarus, I have been making some progress although not much spare time at the moment so have been buying parts needed as they come up at good prices. Some have come from members here, others from ebay and others from Silvers. I now have all the bits for the wheel rebuilds so thats the next job. Forks and yokes all done, rechromed stanchions, polished bottoms, new seals and gaitors etc. The headlamp mounting ears are actually K0 ones in really good condition i got from the USA, although not correct for the year as he will never be a show bike it does not bother me. Next in line is the frame and swing arm, I am trying a new place locally and have left some smaller parts with him to powder coat. We had a discussion about the frame, as it is very pitted and I was thinking the pits may show, so may have it blasted and primed before rubbing down to a smooth finish, then either wet paint or powder. We will decide when its blasted. I have some sub assemblies ready, and have sourced a good seat and a pair of mudguards so starting to come together. Lazarus will rise from the dead!
McCabe-Thiele (Ted)
Reply #131 on:
February 25, 2023, 09:43:30 AM »
Just been reading this whole thread you are making great progress especially looking at your starting point - you must be chuffed Mick.
It will be interesting to see how the frame turns out. I believe there are very good primer filler coats that can hide pitting when using ordinary paint so the primer p/c route should work for you.
FWIW my 400 frame was a tad thick on the powder coating - they managed to completely obscure any sign of the stamped frame number so it hid all the pitting marks.
My 500 frame was powder coated by a different firm clearly much thinner coating - I can still see the frame number by comparison to the above.
Link to my full restoration
Sesman
Reply #132 on:
February 25, 2023, 09:44:29 AM »
Thanks the update…progress is being made. Any pics?
Laverdaroo
Reply #133 on:
February 25, 2023, 11:56:24 AM »
Yesh pleeash!
Oddjob
Reply #134 on:
February 25, 2023, 12:36:29 PM »
Mick, IndexTripleS is the best powder coater I know for frames, he has a custom built blasting cabinet to take frames. If they is a lot of pitting they can put on a high build primer first if you request it. His gloss black is very good, doesn't fade in the sun like some other powder coats do. He's in Bingley, not a million miles away from you.
8
9
10
11
29
Project Board
