Author Topic: 500K2 engine rebuild. Newbie questions  (Read 10240 times)
Re: 500K2 engine rebuild. Newbie questions
« Reply #15 on: February 10, 2022, 07:23:43 PM »
Ok here Phil.
I've included the 650 primary chain tensioner in the last 2 pics so you can see what to look for. One bracket is attached to it.
Offline murdock
« Reply #16 on: February 10, 2022, 07:28:45 PM »
« Reply #17 on: February 10, 2022, 08:48:37 PM »
Thanks Ken and Murdock
Offline murdock
« Reply #18 on: February 10, 2022, 09:12:47 PM »
la parte dificil es conseguir el tensor
the hard part is getting the tensioner
« Reply #19 on: February 11, 2022, 09:43:40 AM »
Indeed it is. I couldn’t readily find a tensioner so decided against the mod.
Offline ebmbiker
« Reply #20 on: February 11, 2022, 12:41:44 PM »
Cheers for the drawings and info guys. This really is a very helpful forum!
I’ll try and find a 650 tensioner before I make the bracket. I reckon once everything is replaced in the primary drive it will be good for years to come as I won’t be doing lots of mileage. The one thing that I’m picking up from reading the posts on the forum is regular oil change, and using good quality oil.
"Fast Beat The Feet!"
« Reply #21 on: February 11, 2022, 12:53:33 PM »
I also think you should consider how your bike will be used and mileage you will be do. My American inport 500k2 (with 11000 miles indicated but not authenticated - so at least that mileage I would guess) had no marks on the cases. I replaced the chain/dampers but I am unlikely to get that mileage on the bike before I snuff it so probably not worth me doing the mod.
There's a few members on here who have done 100,000 plus miles and would be interested to see what their cases are like? I will vary with use and maintenence I suppose
Offline murdock
« Reply #22 on: February 15, 2022, 06:34:43 PM »
 aqui hay un poco mas sobre el tensor
here is a little more about the chain tensioner
                http://www.sohc.co.uk/index.php?topic=11741.0
« Reply #23 on: April 06, 2022, 03:28:11 PM »
Old topic I know but I was looking at some old Kwack primary chains today and noticed that the ZX600 I think it was also had a primary chain tensioner fitted that looks a lot like the CB650 one, it may not be identical but it could be made to work I reckon.
https://www.ebay.co.uk/itm/203865918192?hash=item2f775b0af0:g:JYcAAOSwMS9iLNR~
https://www.ebay.co.uk/itm/373566567673?epid=1323120587&hash=item56fa4d74f9:g:ltoAAOSwFFhgkKt2
« Reply #24 on: May 05, 2022, 06:28:23 PM »
Managed to spot and buy a 650 primary chain tensioner today. It came with a knackered primary chain, of course it may not be knackered but seriously who'd take a chance fitting an old one.
I'll now bung the tensioner and bracket on Ebay unless someone on here wants to buy them both.
