Author Topic: Teds new project a CB500 K1 mostly version 0.5 circa 1972.  (Read 299032 times)
Re: Teds new project a CB500 K0 version 0.5 circa 1972.
« Reply #450 on: February 06, 2023, 01:53:17 AM »
I have three cans.
One is for waste oil etc the 5 gallon one.
One for Petrol 1 gallon - it's over 40 yrs old.
One for Diesel 2 gallons.
« Reply #451 on: February 06, 2023, 03:13:21 AM »
That's like my toolbox..Curver?...  But mine has red clips to secure the lid.
I think it's a Curver copy I've had it for a good 40 years.
Update it is a Curver !
« Last Edit: February 24, 2023, 07:51:18 PM by McCabe-Thiele (Ted) »
« Reply #452 on: February 06, 2023, 03:23:01 AM »
Bike looks like Pat Butcher Ted.  ;D ;D
« Reply #453 on: February 06, 2023, 09:07:33 AM »
Nicely summed up Ken I was thinking Bet Lynch so I've missed the mark a tad.
« Reply #454 on: February 06, 2023, 09:41:07 PM »
I have three cans.
That petrol is probably knackered by now Ted I'm sure the stuff has a shorter shelf life than that  ;);D
« Reply #455 on: February 06, 2023, 09:50:56 PM »
 ;D
« Reply #456 on: February 06, 2023, 09:52:10 PM »
I have three cans.
It's what I use for cleaning engine parts - SUL no expense spared!
« Reply #457 on: February 06, 2023, 11:43:40 PM »
« Reply #458 on: February 24, 2023, 05:15:05 PM »
I've gone back a bit having stripped down the front forks to sort out a stripped thread on the left leg where the top calliper arm is fitted.
As a result I have found that the fork seal that are 35 x 48 x 11 has moved up on one side towards the circlip - there is what seems a big gap as though there ought to be a spacer between the seal & the circlip. When I fitted the seals they were flush at the bottom what's going on here?
.500 fork seal by Macabe Thiele, on Flickr
« Last Edit: February 24, 2023, 05:58:36 PM by McCabe-Thiele (Ted) »
« Reply #459 on: February 24, 2023, 05:45:56 PM »
Wonder if it’s bad fitting Ted? Cant see that it would shift touching against stanchion. Assuming they are correct seals for the job.
Maybe an attempt to get worn seals to seal?
« Last Edit: February 24, 2023, 05:48:22 PM by Johnny4428 »
« Reply #460 on: February 24, 2023, 05:52:56 PM »
I have a vage recollection of early seals being a different thickness from later ones but not sure if it was just 750 or which way. I think there was a service bulletin about it
« Reply #461 on: February 24, 2023, 05:57:37 PM »
They were new seals of the correct size for a 500  - they shifted when I was dismantling the forks -there was a substatntial gap 2-3 mm between the circlip in the groove when they were fitted fully down against the shoulder earlier in the year.
Bryan might be onto something about an alternative seal size being fitted.
« Last Edit: February 24, 2023, 05:59:37 PM by McCabe-Thiele (Ted) »
« Reply #462 on: February 24, 2023, 06:02:17 PM »
Sorry Ted, certainly wasn’t suggesting you had fitted badly! Thought maybe there had been a previous hammer wielding monkey at it. 🤣🤣
« Reply #463 on: February 24, 2023, 06:06:22 PM »
According to parts book the seal should be 35 x 48 x 11, and from what has already told me that's what's printed on the seal. I do seem to recall some seals having a metal spacing washer fitted under the seal, snug fit inside the slider but bore too big for it to ever touch the stanchion. Maybe that's what this needs. After checking my spare sliders I can confirm the shelf the seal sits on is 14.5mm from bottom of shelf to circlip recess, so if the seal is only 11mm that's a 3.5mm gap allowing the seal to move up and down. Doesn't seem a good idea to allow it to do that.
« Reply #464 on: February 24, 2023, 06:14:14 PM »
I agree Ken that is the seal I have 35 x 48 x 11 - the old seal was binned so I can't compare it now but 100% certain there were was no spacer fitted.
