Author Topic: CB500 upper front brake hose routing  (Read 7196 times)
Re: CB500 upper front brake hose routing
« Reply #15 on: September 17, 2022, 09:54:46 PM »
No i dont have the covered stuff, just the hose and fittings left over from a few years back
Offline SPR
  • 1972 500/4 K1
« Reply #16 on: September 18, 2022, 07:48:05 AM »
Might be the change of route will loose some of the excess hose - worth a try just cost a  bit of brake fluid.
Yep worth a go
Offline SPR
  • 1972 500/4 K1
« Reply #17 on: September 18, 2022, 01:53:38 PM »
Good shout by Ted ......
Stripped the calipers to give it a quick coat of paint and flushed the system to use DOT5 .... rerouted the upper hose and also the two throttle cables
The hose may still be a little long but a test ride shows all works as well as before and the headlight area certainly looks better for moving everything
Simon
« Reply #18 on: September 19, 2022, 04:54:06 PM »
Just a word of caution Simon the Silicon Dot 5.0 is not miscible with any other brake fluid - if possible use only after a full dismantling with clean master cylinder, caliper innards, flexi hose & pipes.
If you have just drained the master cylinder & pumped out the fluid using some Dot 5.0 as a flushing agent then after standing for a day I would pump out some fluid from the caliper bleed nipple into a glass test tube or similar to check for traces of the old fluid.
The new silicone fluid  will float on top  - the old fluid will be in a puddle at the bottom like a sediment.
PS Don't ask how I know this.
A short ride might help the shake down.
« Last Edit: September 19, 2022, 06:17:39 PM by McCabe-Thiele (Ted) »
Offline SPR
  • 1972 500/4 K1
« Reply #19 on: September 19, 2022, 08:10:14 PM »
Thanks Ted
All was cleaned prior to use but there could still be residue in the hoses so I plan on further changing of fluid again in a few days
Simon
