Author Topic: What letters are these on the webs of 1 & 2 cod rod codes?  (Read 7545 times)
Re: What letters are these on the webs of 1 & 2 cod rod codes?
« Reply #15 on: January 16, 2023, 11:46:17 AM »
Ted,
Before you spend any money on shells, I would get that crank measured, especially the right hand side (in your pic) main bearing journal - that centre ridge is very noticeable, even with my eyesight!  The big end journals don't look quite so bad but they have full width shells which can hide the truth.
A normal mic anvil might go on the worn section but even a carefully used digital vernier should pick that wear up.
Ian
Graham, does anybody metal spray and re-grind bike cranks these days?
Thanks Ian that has certainly made me look closer at the crankshaft - the big end journals do not have any obvious ridging but the mains certainly do have some ridges that I can feel with my finger nail. Number1 & 4 seem the worse with Number 5 being okay.
Not sure what the availability of good used cranks is on a 500 - I remember back in the day about metal spraying on car cranks.
Not sure what effect the mains ridging would have on a five bearing crank.
« Last Edit: January 16, 2023, 11:52:09 AM by McCabe-Thiele (Ted) »
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #16 on: January 16, 2023, 01:02:55 PM »
Ted, one of those number 4 mains looks like it was fitted with grit or other crap between it and the case.  Have you been into the oil pump yet? (Like Sesman indicated)  The problem with new shells on worn cranks as you probably know is that the oil pressure will suffer as the oil has an easy escape route.
If good, useable 500 cranks are made from unobtainium, then even a costly metal spraying and re-grinding job might still be worth it - dunno, not checked prices.  The last one I had done was a very simple Triumph Twenty One.
Ian
« Last Edit: January 16, 2023, 01:10:18 PM by Orcade-Ian »
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #17 on: January 16, 2023, 01:48:30 PM »
Not dismantled the pump yet.
I've found a crank on e bay but no real idea as to condition.
Update:- Oil pump is in good condition just some feint blotching in places - possibly from standing / water separation.
« Last Edit: January 16, 2023, 02:12:34 PM by McCabe-Thiele (Ted) »
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #18 on: January 16, 2023, 03:30:22 PM »
That sounds great Ted,
Can you get some really detailed pics of all journals from the seller - perhaps even honest, accurate dimensions?
Ian
1972 Honda CB 350/4
2026 Honda ADV 350
« Reply #19 on: January 16, 2023, 05:30:18 PM »
Ian
The seller has a returns policy & has a pretty good reputation so I've made an offer - I bought a rear brake plate from him a few weeks ago that was as he described so i'm optimistic.
« Reply #20 on: January 16, 2023, 08:38:19 PM »
Offer accepted - he who dares ?
Or a fool & his money.
« Last Edit: January 17, 2023, 12:01:52 AM by McCabe-Thiele (Ted) »
« Reply #21 on: January 19, 2023, 05:41:10 PM »
Crank has arrived today - no ridges looks good. When crank & micrometer are both at room temperature I will measure it up.
Not undone the conrods yet.
« Reply #22 on: January 19, 2023, 06:39:06 PM »
👍👍 Great. News Ted.
« Reply #23 on: January 19, 2023, 06:47:32 PM »
NIce one Ted, splendid. ;)
« Reply #24 on: January 19, 2023, 06:48:42 PM »
So far so good just undone conrods the bearings are like new so will not need replacing - I'll check with Platigauge but good start.
« Reply #25 on: January 19, 2023, 06:56:14 PM »
Splendid Ted, there's a leg up for you mate
« Reply #26 on: January 19, 2023, 07:50:33 PM »
About time I had some good luck - not having to buy replacement big end shells will offset against the crank cost quite substantially.
« Reply #27 on: January 19, 2023, 08:01:22 PM »
Quite!
Least you haven't done, forks, lowers, wheels and a new frame!!!
Think you're doing OK mate ;D
