Author Topic: Damaged rear wheel washer and circlip - replacement part  (Read 5660 times)
Offline beemsquar
« on: June 23, 2024, 05:12:50 PM »
Good evening all,
On inspection of my bike I've noticed the the rear wheel washer and circlip have been mangled somehow and are now no longer usable. They are parts 2 and 16 in the Haynes manual and I'm struggling to attach a image.
I don't have a sprocket cover and I'm running an aftermarket sprocket anyway. I also don't have item 18, locking washers and wonder if that's what's caused the problem?
I bought the bike a while ago and am learning as I go. Can someone tell me if the circlip attaches to the bearing retaining ring, or what the purpose of the 3 parts above is, as I can't see what they are holding on or spacing.
As far as I can see, these parts aren't available from David Silver Spares or CMSL.
Any help would be really appreciated.
Also is this safe to ride 10 miles to the garage?
Many thanks.
« Last Edit: June 23, 2024, 05:22:54 PM by beemsquar »
Offline Deano400
Re: Damaged rear wheel washer and circlip - replacement part
« Reply #1 on: June 23, 2024, 05:30:32 PM »
Steve at 400fourbits has the washer and circlip.
https://www.400fourbits.co.uk/#running
Offline Deano400
« Reply #2 on: June 23, 2024, 05:31:22 PM »
Has the chain been off in the past and damaged them?
Offline beemsquar
« Reply #3 on: June 23, 2024, 06:04:36 PM »
Amazing, thanks for the reply. The bike was restored about 8 years ago, so was completely stripped down.
What are those parts holding on? I see no groove in the bearing cover plate for the circlip to slot into.
Would I need the  2 locking washers also?
Offline Deano400
« Reply #4 on: June 23, 2024, 06:34:35 PM »
The groove is on the hub, the washer and circlip hold the sprocket on. IIRC the two locking washers weren't installed originally. Someone on here may know better.
« Reply #5 on: June 23, 2024, 08:46:54 PM »
You will find the 400 Parts Book shows the Hub, washer & circlip as items 155 & 396.
The circlip fits on the hub as has been said see parts book downloadable on here.
155 is  70 mm i/d washer p/n 41202-286-000 washer
397 is a 69 mm circlip p/n 90665-286-000
I would be minded to find a NOS circlip if available - as has been said might have had a chain drop off or my thinking is  circlip was never seated correctly. Not sure if the rear drive rubbers could have started to fall to bits causing sideways pressure?
Steve at 400fourbits  has never sold me a bad used part - you need to e mail him for a price.
« Last Edit: June 23, 2024, 09:16:10 PM by McCabe-Thiele (Ted) »
Offline beemsquar
« Reply #6 on: June 24, 2024, 05:31:37 AM »
Thanks guys.
So the 4 nuts in the diagram don't hold the sprocket on? It looked to me that way. I'm pretty sure the chain hasn't dropped and think it wasn't installed correctly.
I'm assuming it's not safe to ride then?
« Reply #7 on: June 24, 2024, 08:59:11 AM »
I would say do not ride it until the clip is in place.
Easy enough to take the wheel out and check if there is any damage to the hub itself.
The four nuts hold the sprocket to the drive cushions in the hub, the circlip and washer hold the whole arrangement to the hub. Check the parts book to see the fittings.
« Last Edit: June 24, 2024, 09:03:54 AM by McCabe-Thiele (Ted) »
« Last Edit: June 24, 2024, 01:29:40 PM by McCabe-Thiele (Ted) »
Offline beemsquar
« Reply #9 on: June 24, 2024, 09:29:18 PM »
Thank you. I'll check those links out.
« Reply #10 on: June 24, 2024, 10:41:54 PM »
The reason for the circlip and washer is to allow for movement of the spocket when accelerating and decelerating as the drive cushions absorb the inertia involved.
