Author Topic: Keihin jets  (Read 8417 times)
Offline cliff7
Keihin jets
« on: August 03, 2024, 03:14:33 PM »
Can anyone advise me where to get a genuine or quality pattern main jet for my C90. Jets plus has poor reviews and Allen's performance mixed. I prefer to go by recommendation rather than reviews though. Cheers.
Online McCabe-Thiele (Ted)
Re: Keihin jets
« Reply #1 on: August 03, 2024, 03:24:20 PM »
There have been a lot of negative reports about the Keystone brassware, I fitted a full set of Keystone needles and jets to my 400 - it runs like a dream.
Re: Keihin jets
« Reply #2 on: August 03, 2024, 03:30:26 PM »
NRP Carbs are quite good
Re: Keihin jets
« Reply #3 on: August 03, 2024, 05:33:53 PM »
Have you tried looking up the part number at cmsnl then asking your local honda dealer
Offline cliff7
Re: Keihin jets
« Reply #4 on: August 03, 2024, 06:49:05 PM »
Thanks for all the replies. Will get on the phone by on Monday.
Offline shifter
Re: Keihin jets
« Reply #5 on: November 27, 2024, 04:15:41 PM »
Can someone tell me what thread on a keihin pilot jet as I would like to replace  jet that’s broken off and have to be drilled  out and tapped for a replacement .
" RIDDEN NOT HIDDEN"
 Moto morini 250 2c
Cb200
S90
Offline Arch stanton
Re: Keihin jets
« Reply #6 on: November 28, 2024, 03:08:27 PM »
NRP are Keyster kits.
Re: Keihin jets
« Reply #7 on: November 28, 2024, 05:06:30 PM »
Is all keyster stuff no good. I ask as I used keyster float valves and idle jets in my carb rebuild and they worked mighty fine! I didn’t contrast and compare the replacement with the originals microscopically, but the float valves do their job and the bike runs perfectly. The bike won’t take throttle when cold and on choke, but I think “they all do that sir”. And the bike runs perfectly off choke in less time than it takes to zip my jacket and put my lid and gloves on.
Re: Keihin jets
« Reply #8 on: November 28, 2024, 05:16:02 PM »
I've used Keyster on my 400f and it runs fine. There may be cheap Chinese copies about, so be careful where you buy them from.
Re: Keihin jets
« Reply #9 on: November 28, 2024, 05:18:13 PM »
I am of the view that Keyster carb parts are much maligned, my experience with Merc parts is they can have production issues that are later fixed, that does not mean everything they produce is crap.
Easy enough to discredit a manufacturer for one batch error that was later rectified or to perpetuate problems that never existed. It's hard to disprove a negative sometimes. I have seen some manufacturers that produced poor quality parts evolve into top products (Quinten Hazel springs to mind in the 1960's) more recently Blueprint aftermarket parts.
