Author Topic: Clutch siezed  (Read 9339 times)
Re: Clutch siezed
« Reply #15 on: August 17, 2024, 12:16:29 PM »
This is my oil of choice.  8) It's meant for classic bikes in the first place.
I get mine either from Eurocarparts,the 10-40 semi synthetic TQ brand
Or from the VMCC club,
Specially made for the bike
Offline Mikep328
Re: Clutch siezed
« Reply #16 on: August 31, 2024, 02:48:47 PM »
I changed the oil to 10W40 mineral oil.  Made no difference.  I've adjusted the clutch lever free play from spec to virtually none to ensure the clutch is fully disengaged when the lever is pulled but there is no difference regardless of setting.
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Re: Clutch siezed
« Reply #17 on: August 31, 2024, 02:56:08 PM »
How long since you last rode it?
Did you try to free it up before you started it?
It does need doing if left longer than a few days,
You could get a strap, or cable, and tie around the clutch lever and  handle bar,hold the clutch open while parked unused
Re: Clutch siezed
« Reply #18 on: August 31, 2024, 02:57:16 PM »
Could it be an issue with the clutch operating mechanism in the housing rather than the plates sticking ?
The 400 has that odd triangular plate with the three ball bearings in - DS now does a replacement unit.
Re: Clutch siezed
« Reply #19 on: August 31, 2024, 04:54:22 PM »
My 500 has a wormthread,not to bad, the 200 has the 3 balls, works beautifully, light as a feather
The 500 does stick a bit, needs freeing, the 200 never, both use the same oil
Offline Mikep328
Re: Clutch siezed
« Reply #20 on: August 31, 2024, 05:28:32 PM »
It will sit for several days while I do other work so I'll get a better feel for how easily it "releases." Again, it's not a major problem - I can break it loose pretty easily now with the kick starter but the sticking didn't occur until after I was put on a ride following a 5 month layup.  It didn't stick on the first startup after the layup, only after I rode it.  It never did it last year.
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Re: Clutch siezed
« Reply #21 on: August 31, 2024, 06:23:12 PM »
When I rebuilt my 400 the three ball bearings were dimpled and rusty. At that time DS did not sell replacements so sourced a good used part from NJ.
Offline Mikep328
Re: Clutch siezed
« Reply #22 on: September 04, 2024, 05:31:50 PM »
No sticky clutch with the 10W40 Motul mineral oil!  :)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Re: Clutch siezed
« Reply #23 on: September 04, 2024, 05:49:00 PM »
So a different make oil has fixed it?
That's weird even more so as the old oil that was between the clutch plates would not be changed for the new oil straight away but might over time.
Offline Mikep328
Re: Clutch siezed
« Reply #24 on: September 04, 2024, 06:09:37 PM »
I rode it about 20 miles after the oil change and then it sat for several days.  Today, when getting ready to change the brake rotor, I put it in gear in the garage and there was no sticking at all.  Also, the rear wheel did not spin when on the centerstand, engine running in neutral, which it did with the previous oil.
« Last Edit: September 04, 2024, 06:11:45 PM by Mikep328 »
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Re: Clutch siezed
« Reply #25 on: September 04, 2024, 06:18:34 PM »
Not sure if that's viscosity related - is less sticky viscosity linked or is it something to do with the oil shear strength.
Well weird - if it's fixed the problem I guess that's what counts.
It will be interesting to read if the newer DS SS disc changes the braking performance.
« Last Edit: September 04, 2024, 06:20:13 PM by McCabe-Thiele (Ted) »
