Long clutch cable
Topic: Long clutch cable (Read 3997 times)
florence
Long clutch cable
August 21, 2024, 03:57:58 PM »
Does anyone know if there is a Honda clutch cable which would fit 500/4 but is about 1.3m in length? The cable on mine has gone a bit sticky and I cannot remember what I used, it was so long ago. Might have been XL500?
I was hoping not to have to take it off so I can carry on riding until a new cable is ordered.
Last Edit: August 21, 2024, 04:01:14 PM by florence
JamesH
Re: Long clutch cable
August 21, 2024, 05:03:30 PM »
Wemoto sell a universal clutch cable ‘kit’ that you can use to make the exact length you need. I used it on the Cb750 chipper project.
mickwinf
August 21, 2024, 05:16:21 PM »
I have a new one that was far too long for my standard handlebar 500, I can measure it for length
florence
August 21, 2024, 05:18:14 PM »
thank you both
Mike_Berkshire
SOHC Expert
August 21, 2024, 05:45:17 PM »
Looks like you have a solution but something that may be helpful if not is that the US spec CB550 cables and upper brake pipes are longer for the higher US type handlebars. I fitted UK flat bars and without thinking it through ordered an upper brake pipe from DS for my (US import) bike that was way too long.
Seabeowner
August 21, 2024, 06:49:18 PM »
I have slightly higher bars on a 500. Can't be much help but can tell you that the UK type sold by DSS is 1.04. The one sold by Andy Cepok (bought on ebay) is 1.04. Also have a original Honda p/n 22870-323-020 (which is for the US spec) that I fitted last week is 1.12m.
Measurements are outer (inc fitgs), so nothing comes close to 1.3m. (+11cm if over inner.)
Last Edit: August 23, 2024, 01:53:41 PM by Seabeowner
1971 CB500K0 Candy Jade Green or Candy Gold
1973 CB500K1 Candy Ruby Red
1975 CB550F1 Shiny Orange
McCabe-Thiele (Ted)
August 21, 2024, 08:25:08 PM »
Genuine clutch cable for 500 K1 is 42" ferule to ferule or 107 cms according to an old post by Ken (Oddjob).
Last Edit: August 21, 2024, 11:40:23 PM by McCabe-Thiele (Ted)
Link to my full restoration
Mike_Berkshire
SOHC Expert
August 22, 2024, 09:51:27 AM »
I just measured the old one from my US import '76 K2 550 and from ferrule to ferrule end it is 120cm
florence
August 22, 2024, 10:37:19 AM »
I used to frequent a friendly bike shop that let me go round the back and measure cables and find something that would fit. It was usually something off a motocross bike that would do the job. Sadly, no longer trading.
Anyway, I think Ted is sending me something so thank you all for your advice.
Last Edit: August 22, 2024, 10:41:48 AM by florence
McCabe-Thiele (Ted)
August 22, 2024, 10:42:51 AM »
The clutch cable I had is now re-homed it's about 121.9 cms long so should be a good fit.
It was too good to bin as it had virtually not been used - it was a good 6"-7" too long on my UK 500.
florence
Reply #10 on:
August 22, 2024, 11:54:16 AM »
you're a superstar Ted, many thanks
McCabe-Thiele (Ted)
Reply #11 on:
August 22, 2024, 03:57:17 PM »
If yours has that strange screw thing on the casing for the clutch adjustment definitely worth dismantling, cleaning and re-greasing all the bits.
IIRC there is a seal that is supposed to keep the water & dirt out - clearly they are not 100% effective if the condition of mine was anything to go by.
Long clutch cable
