Author Topic: exhaust  (Read 6680 times)
Offline Morala
exhaust
« on: December 09, 2024, 11:25:48 PM »
Hi everyone, can somebody explain the reason for the rubber connector  that joins the two silencers on my 1974 550, thanks for any advice you can give me.
Offline ozzybud
Re: exhaust
« Reply #1 on: December 09, 2024, 11:55:06 PM »
Likely similar reasons dual exhaust cars have "H'" pipes
here is an AI answer for h pipes.   likely gives it a better sound.
Cars have H-pipes in their exhaust systems to help equalize exhaust pressure between the two sides of the engine by creating a crossover point, which can lead to improved engine performance, particularly by enhancing low-end torque and smoother power delivery, especially on vehicles with dual exhaust systems; essentially, the H-pipe allows exhaust pulses from one side of the engine to interact with the other, promoting better gas flow.
« Last Edit: December 10, 2024, 12:05:44 AM by ozzybud »
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
Re: exhaust
« Reply #2 on: December 10, 2024, 12:02:12 AM »
Somebody in Hondas R&D in the late 60's worked out you got a slight increase in power with it fitted
Re: exhaust
« Reply #3 on: December 10, 2024, 06:51:59 AM »
Bryan, have you got “convert characters to emojis” set in your PC?
Re: exhaust
« Reply #4 on: December 10, 2024, 08:23:32 AM »
Yes, when these 'balance tubes' are more towards the end, there's a slight increase in high rpm's, the more towards the head, you gain somewhat in the lower range. That's the idea. Personally I don't think ours make much difference. After all... Honda dropped them when they launched the K3's.
Re: exhaust
« Reply #5 on: December 10, 2024, 10:57:55 AM »
Absolutely no idea what you are talking about Steve
Re: exhaust
« Reply #6 on: December 10, 2024, 11:05:54 AM »
Nor me.
Re: exhaust
« Reply #7 on: December 10, 2024, 11:54:03 AM »
Clearly a phone thing...
Re: exhaust
« Reply #8 on: December 10, 2024, 12:34:32 PM »
Well i was on my dumfone when i wrote it, the pc is still running 98 and the laptop 7!
Offline Morala
Re: exhaust
« Reply #9 on: December 10, 2024, 06:55:15 PM »
thanks for all the advice, was wondering if the connectors can be removed without causing any problems as it is a real bore trying to line the connectors up so would it be possible to seal the openings on the exhausts or will it cause the bike to run badly cheers.
Re: exhaust
« Reply #10 on: December 10, 2024, 09:16:31 PM »
Probably not, only the nit pickers will be upset
Offline Murf
Re: exhaust
« Reply #11 on: December 11, 2024, 11:59:21 AM »
As Bryan says leave them fitted or you will be harassed by the classic bike police every time you take it out 😄😄.  Well the lack of them will definitely be pointed out to you.
I haven’t got a 5mm diameter red dot 🔴 painted on the front brake caliper of my CBX and I am always being told about  the error of my ways.  Now I have become stubborn and won’t put it on 😂
Re: exhaust
« Reply #12 on: December 11, 2024, 12:56:14 PM »
Hey, Murf. Put two red dots on. That should mess with their heads. Then tell them it’s an American model!
Offline Martin6
Re: exhaust
« Reply #13 on: December 11, 2024, 01:27:19 PM »
Or HRC.
Re: exhaust
« Reply #14 on: December 11, 2024, 01:38:11 PM »
