Author Topic: Rear hub seized, can’t get to cush drive.  (Read 9559 times)
Offline SteveW
« on: February 22, 2025, 07:22:04 PM »
Just removed rear wheel to strip the hub as I’m putting new rims on.
Can’t remove the rear sprocket assembly, it’s as if the cush drive is welded to the hub.
Tried with a piece of wood across the wheel and a crow bar under the sprocket, you can see it move a tiny fraction of a mm but won’t come apart. Tried heat, WD40, nothing will shift it.
Taken many hubs apart over the years, never come across this.
Any ideas? 74 550 K0.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline TezzerTel
Re: Rear hub seized, can’t get to cush drive.
« Reply #1 on: February 22, 2025, 07:42:16 PM »
If in doubt give it a clout
If your not sure give it some more 😂
« Reply #2 on: February 22, 2025, 08:14:44 PM »
I take it you’ve got the retainer ring removed Steve?
Offline SteveW
« Reply #3 on: February 22, 2025, 08:26:52 PM »
No, retainer ring is still fitted.
Just realised that might be the culprit. On every bike I’ve ever worked on they just pull apart.
Is the retaining ring a left handed thread?
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline TezzerTel
« Reply #4 on: February 22, 2025, 08:38:52 PM »
My one was a left hand thread. It came out the opposite way to the arrow on it. I thought the arrow would be the way it came out
« Reply #5 on: February 22, 2025, 09:42:09 PM »
Yes I’m sure it’s a left hand thread.
« Reply #6 on: February 22, 2025, 10:16:33 PM »
Not the first, wont be the last, yes its LH thread and check for staking marks down the holes, they can be kin tight as well
Offline SteveW
« Reply #7 on: February 22, 2025, 10:43:41 PM »
Thanks guys, I’ll give it a go tomorrow.
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline Seabeowner
« Reply #8 on: February 23, 2025, 07:05:55 PM »
Steve, if it's difficult I have the tool that fits in the four holes. Some try bashing at one hole, some make something to fit two holes. But using all four is best.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline SteveW
« Reply #9 on: February 28, 2025, 07:33:22 PM »
Hi Phil, thanks for the offer but it came off really easy in the end.
Made a bar with a couple of M6 bolts sticking out to engage in the holes, worked a treat.
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline Murf
« Reply #10 on: May 09, 2025, 12:37:28 AM »
I was just about to remove the retaining ring on mine this afternoon when I noticed that it is staked on all of the four parts you can see.  I generally just drill any staking I come across with a small drill just to clear it, do you think that will work on this.
Then I guess it’s off to make yet another special tool to remove the retaining ring.
Good to know about it being a left hand thread, the arrow on mine is not really distinguishable any more, it’s  just a faint line now.
« Reply #11 on: May 09, 2025, 07:36:20 AM »
Yes, small drill and drill out the stakings
« Reply #12 on: May 09, 2025, 07:44:48 AM »
As has been said the 500 is left hand thread on the rear retainer, the 400 is a normal RH thread.
« Reply #13 on: May 09, 2025, 12:39:12 PM »
Quite a few members have the special tool needed to remove the retainer, maybe give out your location and see if anyone is local to you that can help out.
