Author Topic: Replica front mudguards from David Silver  (Read 7424 times)
Offline SteveW
« on: March 28, 2025, 10:56:49 AM »
Has anyone bought one?
Just wondering what the fit / quality is like before I possibly get one for my 550.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Replica front mudguards from David Silver
« Reply #1 on: March 28, 2025, 11:11:21 AM »
I fitted one to my 500, IIRC it has slightly bigger bottom fittings with rubber eyes, mine fitted after a bit of a struggle.
It was getting the stays to sit right that was a fiddle, link to my post, unfortunately the photo was deleted by me on Flickr.
www.sohc.co.uk/index.php/topic,29256.0.html
« Last Edit: March 28, 2025, 11:28:49 AM by McCabe-Thiele (Ted) »
Offline Athame57
« Reply #2 on: March 28, 2025, 02:30:33 PM »
You try fitting one of their tanks!  :o
1978 CB400F2 named Elen.
« Reply #3 on: March 28, 2025, 04:14:23 PM »
I did wonder if they ever altered the tank design from the supplier after your fitting problems.
Offline SteveW
« Reply #4 on: March 28, 2025, 05:20:45 PM »
Could I use my existing stays on the new mudguard?
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #5 on: March 28, 2025, 08:12:41 PM »
in theory yes, in practice who knows, you may well be the guinea pig
« Reply #6 on: March 29, 2025, 12:01:16 AM »
If it helps I did eventually get the stays to fit, I loosened the stay to fender bolts considerably, the main culprit was the end of one stay where the metal is doubled up, the back layer was a tad on the wide side. I did not want to grind off the excess as that would have removed the chrome plating. A small amount of extra bend angle on the fork end of the stay enabled it to fit, I then tgihtened up the stay to fender brackets last.
Offline Athame57
« Reply #7 on: March 29, 2025, 05:45:13 AM »
I think DSS is big and organised enough to supply some instructions from the start when these things are needed.  :o
Offline TezzerTel
« Reply #8 on: March 29, 2025, 07:47:10 AM »
Mine fitted ok.  It was a bit of a wrestle to get the stays on to the fork but not too difficult
