Author Topic: 1976 CB250 G5 Float height for 745B Carb  (Read 16937 times)
Re: 1976 CB250 G5 Float height for 745B Carb
« Reply #15 on: June 17, 2025, 08:54:05 PM »
The amount they hang down is of no matter as long as they shut off the fuel at the same level.
I can only assume that the tang to stop them hanging down too far is to make it easier to fit the float bowls, cant think of any other reason
« Reply #16 on: June 17, 2025, 11:18:50 PM »
I think it’s there to stop the float needle falling out if the float was able to fall as far as it liked.
Offline rbt1548
« Reply #17 on: June 18, 2025, 09:33:37 AM »
Thanks, I'm just going to set them both at the same drop when vertical after ensuring that they both are the correct measurement when done the service manual way.
