Author Topic: Fuel reserve...worth checking how much you have.  (Read 4893 times)
Online Mikep328
« on: May 06, 2025, 12:51:42 PM »
  I just got around to doing that today on my 400.  I put it in the normal fuel position and drained the fuel.  Then I switched it to the reserve position to see how much more fuel there would be.  Turned out there was NONE.  So I pulled the petcock.  The plastic filter/ tube assembly was totally jammed in the tank fitting, as if the plastic had expanded over the years - I had to work it out with pliers.  And it was obviously not seated properly in the petcock so the petcock was just picking up fuel from the bottom of the tank at all times.
So I ordered a new filter tube/the two gaskets from DSS.  I'd been meaning to check this since I bought the bike nearly two years ago but once again found that "meaning to" do something never seems to actually get it done! ;)
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Online Mikep328
Re: Fuel reserve...worth checking how much you have.
« Reply #1 on: May 11, 2025, 11:08:42 AM »
Installed the new filter (genuine Honda).  The old filter was a pattern part apparently and did not fit properly.  I poured two liters of petrol in the tank, turned the petcock to the "normal" position and no fuel came out; turned it to reserve - good strong stream.  So now I know I have a properly functioning "reserve" although I still don't know how much fuel is in the tank when reserve is called for, which was the point of the exercise in the first place.;)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline TrickyMicky
« Reply #2 on: May 12, 2025, 10:38:19 AM »
Maybe I've got this arse upwards, but, if you put 2 litres in the tank and nothing flowed from the "normal" position, keep pouring measured amounts until it does flow, that will give you the amount in reserve.
Offline exvalvesetdabbler
« Reply #3 on: May 12, 2025, 10:41:00 AM »
If you slipstream a box van on a quiet A road, you should easily do 40 miles on reserve. Always used to happen on a Sunday afternoon when all the rural petrol stations were shut or you could only get 4*.
Dave.
Online Mikep328
« Reply #4 on: May 12, 2025, 02:02:04 PM »
"Maybe I've got this arse upwards, but, if you put 2 litres in the tank and nothing flowed from the "normal" position, keep pouring measured amounts until it does flow, that will give you the amount in reserve."
Absolutely right but I don't have a gas can (or a garage to keep/store tools, etc).  The bikes and car are in parking slot 3/4 mile away from the house. :(  When I drained the tank I drained it into 3 wine bottles I picked out of a local rubbish bin and poured them into our Mini's gas tank as they filled.  I kept two wine bottles filled with gas under the bike's cover and that's all I had to pour back in!
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline honda-san
« Reply #5 on: May 12, 2025, 07:29:47 PM »
FWIW, our 400/4's (which all have standard fuel tap arrangements) have pretty well exactly 3 litres reserve, 11 litres main (so 14 litres total).
Chris R.
Online Mikep328
« Reply #6 on: May 12, 2025, 10:44:32 PM »
Thanks!!
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
