Author Topic: CB750 charging system  (Read 7101 times)
Offline Grewth
« on: September 03, 2025, 12:46:00 AM »
Anyone fitted the bargain basement combined rectifier regulator units being sold on ebay  ?
£20 - £25 seems to be the going rate,
DSS want around three times as much for a similar pattern item
I wonder if they're actually any better  ?
Re: CB750 charging system
« Reply #1 on: September 03, 2025, 12:52:25 AM »
Maybe, maybe not but at least he will take it back if it dont work and it comes with instructions
« Reply #2 on: September 03, 2025, 06:41:34 AM »
Yes I tried them, it failed in about 5 days. I then fitted a well made unit from Electrex World and it's been right ever since. Cost a lot more obviously, but as they say buy cheap buy twice. I could have sent the failed unit back but couldn't be bothered so I just binned it. Electrex products are UK made and top quality, worth every penny if you don't want to be stranded at the side of the road.
Offline TrickyMicky
« Reply #3 on: September 03, 2025, 07:55:50 AM »
I fitted the DSS one to my 400 9 years ago, so far so good.  As there is not as much space as on the 750,  I managed to concoct a small mounting plate and used the area where the original voltage control unit was.behind the left side cover.
« Reply #4 on: September 03, 2025, 08:03:31 AM »
I should clarify that the one I fitted that failed was a cheap Chinese eBay item not the Silvers unit.
Offline Grewth
« Reply #5 on: September 03, 2025, 09:59:16 AM »
Good point.
With ebay you might get your money back eventually,  after the seller has tried to insist that your bad motorcycle killed his good rectifier regulator.
Offline Grewth
« Reply #6 on: September 03, 2025, 10:03:33 AM »
I've just been made aware of another option.
Maybe a bit of a cowboy solution, but it could possibly work well.
Just buy a car alternator rectifier and use that in conjunction with the original electric/mechanical voltage control box.
I put Chinese bits in my Lucas alternator about five years ago.
No problems since
« Reply #7 on: September 03, 2025, 10:10:02 AM »
Your choice, good luck.
