Airbox rubber Seal
Topic: Airbox rubber Seal (Read 5376 times)
Peterplank
Newbie
Airbox rubber Seal
February 08, 2026, 04:16:58 PM »
Hello all,
At the point of putting carbs back on after rebuild and finding more to do of course..
I'm looking for a replacement rubber seal that goes between the 2 black main airbox parts, can anyone point me in the right direction please ?
The main box not the air filter itself
I can't see it on the David Silver or cmsnl drawings...
Last Edit: February 08, 2026, 04:30:50 PM by Peterplank
500-4 K1
DR-350
600RR7
Re: Airbox rubber Seal
February 08, 2026, 04:44:29 PM »
Thats because it was never a seperate part, i think it comes with the plenum chamber
Peterplank
Newbie
February 08, 2026, 05:54:50 PM »
Ah ok, that explains it...
Hot soapy water it is then
500-4 K1
DR-350
600RR7
deltarider
My kingdom for a turkey!
February 09, 2026, 11:54:21 AM »
Could a part cut out of a pedalbike's inner tube help you?
Oddjob
February 09, 2026, 04:23:17 PM »
IIRC the seal used to clip onto the rim of the plenum chamber. It’s like the letter U. Honda used a very similar sort of seal on the edge of the seat pan to stop the pan from cutting into the cover. Surely something similar can be found online. Other that that some stick on foam should do the job, it’s only stopping any unfiltered air from getting into the intake.
Johnwebley
February 10, 2026, 08:37:15 AM »
You could try using fuel tubing,
Slit it open, the see how it fits,
Might need to experiment with different sizes
Airbox rubber Seal
