CB350/400
CB400 Front Bearing Retainer Removal
Topic: CB400 Front Bearing Retainer Removal (Read 3673 times)
element137
Newbie
April 08, 2026, 03:31:26 PM »
All- thought I would post this up here as it might help someone with similar problem, chewed up and seized front bearing retainer - this is how it started -
element137
Newbie
Re: CB400 Front Bearing Retainer Removal
April 08, 2026, 03:38:15 PM »
So after drilling out the staking - used a dremel and drill on the inside edge of the retainer to try and break it free, then used a punch to collapse it on itself and 'peel' it out of the hub
Oddjob
April 08, 2026, 04:40:45 PM »
You can normally just break it with a cold chisel due to it being alloy. A Dremel risks the chance of thread damage IF you go a bit deep or it veers off target. Drive the chisel in off the edge and towards the bearing and it normally breaks where the slots are for the special tool.
element137
Newbie
April 09, 2026, 07:42:07 AM »
I managed to extract- combination of very careful dremel/drill/ punch to fold it in on itself - there is evidence of damage to the threads in the hub from previous drilling of stakes, but overall the threads cleaned up quite well with a thread file
CB350/400
