Author Topic: Indicator Buzzer location & Bracket ?  (Read 6441 times)
Offline Coppertop1234
  • As long as the wife is happy
« on: May 26, 2026, 08:25:12 PM »
I know these are not to every ones liking, but we have dropped on a couple of original indicator buzzers.
We used to get these off goldwing riders who soon got annoyed with them in the 70's
I think I remember on the 750 F1 we had a mounting bracket with a square hole which was mounted up near headlamp to fit the buzzer into.
I am looking to fit to the 400/4 but a bit stumped at the moment as to where it should mount and if there is a bracket on bike or one i need to source/make.
If anyone has a picture of correct mount or where it should fit on bike it would be appreciated.
« Last Edit: May 26, 2026, 08:30:10 PM by Coppertop1234 »
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650   Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1  Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream    Restoration
1977 CB400/4  - The last one - Restoration
Re: Indicator Buzzer location & Bracket ?
« Reply #1 on: May 26, 2026, 09:01:32 PM »
found a pic on a f1 mounted under speed near ignition
looks like its a wire for rubber to insert into
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #2 on: May 27, 2026, 12:50:30 PM »
Not sure about the 400 but the 550F has it mounted on the inside of the fork ear. The reinforcing plate welded to the ear itself. The nearside one has the square hole punched through it. Maybe check there on the 400.
« Reply #3 on: May 27, 2026, 03:44:47 PM »
I think they were only fitted to JDM models, like the speed sensor was JDM only. I know they were never fitted as standard to UK models, so maybe there is no fitting bracket for it as standard.
« Reply #4 on: May 27, 2026, 04:16:55 PM »
Cheers for info
Well if everything else is done I can spend some time in garage and make a couple of brackets
Didn't want to if there was a standard bracket out there or on bike
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #5 on: May 27, 2026, 04:52:50 PM »
You could try fitting it to the speed sensing bracket fitted to the left hand side of the top frame tube and below the front of the fuel tank. As Julie said, the speed sensor wasn't fitted to UK bikes but the bracket is still there and it is basically used to support the wiring loom on the left hand side from the headstock.
« Reply #6 on: May 27, 2026, 05:37:48 PM »
Good idea Dave
Seen the bracket and thought it was a bit of an oddball.
I will see whats , what when it lands
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Offline Mikep328
« Reply #7 on: May 28, 2026, 10:40:09 AM »
Why not forget about it and leave them blinking like everybody else does!!!  :)
Rode behind a guy on a Triumph Bonnie yesterday who had his right blinker flashing for nearly 10 miles.  He finally "fixed it" when he had to make a left turn...  ::)
Not like I haven't done the same thing...with the blinker light on the dash flashing away...
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline TrickyMicky
« Reply #8 on: May 28, 2026, 02:13:01 PM »
  Alcoholic reasoning:- To save faffing about with extra wiring, when you operate the indicators, make the loud beeping noise with your mouth. Pedestrians will certaionly look at you, and you most definitely will not forget to cancel the indicators!! Logical???
« Reply #9 on: May 31, 2026, 05:09:41 PM »
Made a pair of brackets 1 for each bike
Fitted under speedo and mounted buzzer
Connected buzzer to blue and white and Orange and white wires in headlamp
Tank off harness under tank found blue /white and orange and white connectors
2 New wires from flasher unit threaded through to couple up to same connectors under tank
Indicators flash and buzzers beep as they should.
looks like its always been there  :)
« Last Edit: May 31, 2026, 05:21:36 PM by Coppertop1234 »
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
« Reply #10 on: May 31, 2026, 08:51:45 PM »
That would drive me nuts!
« Reply #11 on: May 31, 2026, 09:47:19 PM »
I have one fitted to my CD250u, standard kit on these, Graham has disconnected the one on his CD250u but he says I can't be trusted to turn the indicator off so I need the beep to remind me 🙄🙄🙄. It is a total pain, I absolutely hate it and I can see why at one time they were banned, I think it was to save the sanity of the rider and everyone close by as well as for safety reasons.
« Reply #12 on: May 31, 2026, 11:16:08 PM »
I’ve always liked them. In fact I’ve plans to refit mine, I will be reusing it for another purpose. Secret, don’t ask 😀😀
« Reply #13 on: May 31, 2026, 11:39:58 PM »
Side stand alarm?
« Reply #14 on: June 01, 2026, 12:09:04 AM »
I’ve already mentioned it before Ted, thought you lot might have forgotten though. Yep, side stand alarm. If you get a set of 4 into 4 for your 500 Ted, test the side stand doesn’t hit the outer exhaust when it goes up, leaves a hell of a dent over time. Most have a slight bend in them from being left down. Gonna try an induction coil and a press to see if I can straighten mine.
