Author Topic: Seat wobble  (Read 88 times)
Online Anderzander
Seat wobble
« on: November 20, 2026, 10:26:38 PM »
Very basic question… as I’m new to the bike.
My seat has quite a bit of wobble - like the sprung pin latches but doesn’t pull down tight enough. With the seat lifted the whole spring bit wobbles quite a bit.
I also noticed that the two collars that fit inside the rubber bush are longer than the rubber bushes - so when it’s clamped up there is no tension on the rubbers to firm it up.
It’s only got 12k miles on it - and nothing looks worn .. so is that how they are ?
CB750 K3
Offline Athame57
Re: Seat wobble
« Reply #1 on: Today at 08:20:37 PM »
It sounds like my loo seat was until I got someone else to fit the new one.  ;D I had some problems with my own CB400F because it was a non standard seat I had at first and when I got a standard (pattern) seat I had trouble locking it down. I found rubber stops associated with that first seat fitted to the frame were stopping things so I remove them and end up with the metal tongue at the seats front rubbing through the covering and scraping my tank. I eventually got it sorted out, that was about seven years ago though.
I think you might want to post some photos of the seat bottom and frame fittings for the CB750 buffs to look at?
1978 CB400F2 named Elen.
Online Anderzander
Re: Seat wobble
« Reply #2 on: Today at 08:37:04 PM »
Thank you - photos are a good idea. Maybe I can make a short video and link to it…. 🤔👍🏻
I’m just trying to figure out what’s normal. I’m thinking that the rubber may have shrunk ? and that’s why it’s just clamped on the spacer things …
I will return with pictures !
CB750 K3
