Author Topic: Original side stand  (Read 278 times)
Offline Athame57
Re: Original side stand
« Reply #15 on: Today at 09:45:58 AM »
Many newer bikes use a switch in series with neutral light, that to cut ignition if you put it in gear with stand down.
I think that there was a time when inability to start with the side stand down was exclusive to the Kawasaki Z750 LTD?
1978 CB400F2 named Elen.
Offline Reborn 400
« Reply #16 on: Today at 10:05:44 AM »
Hi George,
Yes I see the drawing, so your side stand at present looks like this?
Offline Reborn 400
« Reply #17 on: Today at 10:06:46 AM »
....and what you are looking for is one like this?
Online McCabe-Thiele (Ted)
« Reply #18 on: Today at 10:37:42 AM »
When I had an XJ900 it took me a while to work out why the engine sometimes stalled when I put it onto gear.
The penny dropped eventually!😁
Offline Athame57
« Reply #19 on: Today at 11:03:36 AM »
Yes, mostly because I thought something had broken off what I have. As it has turned out I may be able to modify what I have. At our age senior moments become more common (for instance  I'm forever going back upstairs because I forgot my riding glasses!) so it sound like a good idea!  ;D
« Last Edit: Today at 11:05:54 AM by Athame57 »
Offline Reborn 400
« Reply #20 on: Today at 11:53:10 AM »
I know that situation well! I talk to my cat a lot....it's just an excuse to talk to myself, really. I'll walk into a room and then say out loud - "what have I come in here for?"
Online badger_eng
« Reply #21 on: Today at 11:54:22 AM »
George
Not sure how to add pics to PM’s so here they are….
Straight out of the vice!
Yours at postage only if you want it.
Pete
Current:-
Suzuki GSX-S1000GX+ - 2026
Suzuki GT500A Cafe style - 1976
https://www.kettleclinic.co.uk/kcforum/viewtopic.php?t=14273
Honda CB550K - 1977 (Winter 2026/27 project)
Offline Reborn 400
« Reply #22 on: Today at 11:57:54 AM »
Nice neat job there Pete
Online badger_eng
« Reply #23 on: Today at 12:14:08 PM »
Thank you….
I took a real quick look at it yesterday when I removed the sidestand and was always my plan to remove. I was just going to dremel disc it off and blend the contours, then totally by chance read George’s post later.
Anyway, found a nice cut line / approach and it came off easier than I expected and it’s 99% unscathed.
I wouldn’t try stick personally to re-attach as my stick welding on low gauge is very average but Mig / Tig should be fine.
This sidestand looks like it’s a whole cast unit.
I extended the length of the sidestands on my CX500 and GT500 as the rear shocks I fitted were a bit longer. They were both hollow so I had to chop them, fill the void with a length of steel rod. Made up the profile with weld then blended with a grinder / file before powdercoat.
Current:-
