Author Topic: Crankshaft seal behind points  (Read 3839 times)
Offline bluemouse1006
« on: May 17, 2012, 05:53:30 PM »
Hi
I've fitted a new crank seal behind the points plate o my cb750 SOHC when I rebuilt my bike a short while ago . From what I remember it was a right pain to fit ( it's the original from dave Silver) the edges where serrated and it didn't go in that well , anyone had the same problem ? Is there another seal available somewhere else ?
Thanks again
Look forward to hearing your comments
Amos
Amos
Re: Crankshaft seal behind points
« Reply #1 on: May 17, 2012, 06:06:41 PM »
I assume you fitted the seal BEFORE joining the top and bottom casings? Trying to fit that seal with the cases assembled is 99.9% likely to fail :'( If done properly with the cases apart, the seal sits in a groove machined in the casings ;D
« Reply #2 on: May 17, 2012, 07:24:03 PM »
Whoops
Thought it would be something like that .
Any way this can be sorted without splitting the cases again ..
Amos  :)
Amos
« Reply #3 on: May 17, 2012, 09:05:52 PM »
The only way to guarantee a leak free seal is to split the cases I'm afraid :( It probably can be done with the engine complete, but will almost certainly start leaking again :'( DO NOT be tempted to use sealant for a quick bodge, too much risk of it getting inside the motor, often with horrendous consequences :o
« Reply #4 on: May 18, 2012, 08:40:13 AM »
Hairy
Thanks for that , really don't want to split the casing again will be taking out the seal today and having a look .
The leak is getting oil all over the foot peg now so will have to sort it.
I'll keep you updated
Amos (Bluemouse 1006)
Amos
« Reply #5 on: June 02, 2012, 06:04:19 PM »
Bought a seal from a local seal and bearing shop although it was a mm thiner , I've done about 100 miles after fitting in the usual way and it's still as dry as a bone !!
Hope fully it will be fine now
Thanks for the advice
Amos
Amos
