CB750
Fork Oil
Topic: Fork Oil (Read 18051 times)
kifer
SOHC Member
Fork Oil
June 27, 2012, 09:21:44 PM »
Just replaced stanchions this afternoon with some nos ones have had for a while, Made the mistake of looking in 3 different manuals at amount of oil and guess what they all vary. Can you help with cc's for an F1 please. sure have normally used about 215cc ?
Also noticed the one oil lock had 2 quite bad grooves at the top I would presume this is from a previous ham fist and not from the rebound spring. Have replaced lucky had a couple knocking about.
Re: Fork Oil
June 28, 2012, 05:48:35 AM »
Not sure what you mean by oil lock mate
Waggles
SOHC Expert
Re: Fork Oil
June 28, 2012, 07:47:29 AM »
I think 215cc is a bit much, I beleive it is 150ml for an F1, bit less if refilling after an oil change, will check that tonight to make sure my memory hasn't played tricks
Spitfire
Re: Fork Oil
June 28, 2012, 09:04:15 AM »
Hi there, I've just checked my CB750F Supplement and it states 145-155cc.
Den
kifer
SOHC Member
Re: Fork Oil
June 28, 2012, 09:36:18 AM »
Cheers to all, just looked through books again now I am confoooosed Haynes 220-230. Clymer 207-213, 160-162,
Shop 220-230, I would say these may be for dry fill which is what mine are,
The oil lock is the small hollow bush where the rebound spring sits at bottom of lower fork leg.It looks like a top hat with a hole through it I may have the wrong name would normally call it the thingy at the bottom when discussing in shed.
Spitfire
Re: Fork Oil
June 28, 2012, 10:12:22 AM »
Here's the Specs section from the supplement that Honda issued for the CB750F.
The Honda manual for the original CB750 gives a figure of 220-230 cc, but the forks are different to the CB750F ones.
Den
kifer
SOHC Member
Re: Fork Oil
June 28, 2012, 11:07:32 AM »
Cheers Den, Thanks for taking the time to post spec list, For the lay man like me some of the manuals are a s**t that's the reason I like to check if not sure. some questions I ask must sound a bit mainstream to you lads Thanks again.
Spitfire
Re: Fork Oil
June 28, 2012, 01:34:28 PM »
I can see where the confusion comes from, I looked at the specs in a few of my genuine Honda manuals (not Clymer or Haynes) and got the following
CB750 (Original CB750): 220 - 230cc
CB750K2, K3, K4: 220 - 230cc from dry, 155 - 160 after draining.
CB750F: 145 - 155cc
CB750F2: 1977 145 - 155cc
CB750F2 and K8: 135 - 145cc from dry and 145 - 155 after draining.
Den
billy192
SOHC Expert
Re: Fork Oil K6
August 13, 2012, 09:38:18 AM »
Hi,
I am just about to change the fork oil in my 1976 K6.
Am I correct in thinking it is 220 - 230cc from dry, 155 - 160 after draining?
Billy
Waggles
SOHC Expert
Re: Fork Oil
August 15, 2012, 11:07:11 AM »
Think the forks were basically the same until the F1 so yes you are correct, F1 and F2 as quoted above, not sure about K7 but I assume same as F1
CB750
Fork Oil
