Author Topic: Front mudguard item prices  (Read 1905 times)
MIKE550/4
« on: October 28, 2013, 06:55:56 PM »
not usually one to moan about prices but this seems excessive for such little parts
6 rubber washer mounts  40513310000
6 collars   40514310000
6 bolts   92101-060200A
47 quid delivered ? for basically 6 rubber washers, 6 bolts and 6 collars
is there an alternative ..... hardware shop ?
Offline mickwinf
Re: Front mudguard item prices
« Reply #1 on: October 28, 2013, 07:57:45 PM »
I reckon its these small items which cause the cost of restoration to spiral to a level you never expect. the larger items are easy to estimate but all these little bits add up!
Offline peterengland
« Reply #2 on: November 08, 2013, 03:52:50 PM »
hell, I would just go to the hardware shop, a bolt is a bolt and as long as it does the job, what the hell?
Suzuki 50
Suzuki GT185
Honda CD175
Yamaha RD350
Honda 50 crunch box
Honda 400/4
Honda 550/4
Honda 750C
« Reply #3 on: November 09, 2013, 06:50:25 AM »
 A bolt yes but you can't get the top hat washers or special sized grommets at the local hardware shop
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: November 09, 2013, 02:19:20 PM »
Surely the tyre will let go before enough stress is put on those bolts.
MIKE550/4
« Reply #5 on: November 09, 2013, 03:56:27 PM »
well I forked out in the end, the bolts I could get elsewhere, the top hat washers and grommets I have not seen anything else like this in hardware shops so they had me over a barrel really
