Author Topic: Help can't get cam chain back on  (Read 12181 times)
Offline WPF81S
« on: November 27, 2013, 11:13:40 AM »
Am I doing something wrong just can't get cam chain back on 1 hour so far. Is there a special way?  Iain
Re: Help can't get cam chain back on
« Reply #1 on: November 27, 2013, 12:24:34 PM »
Ian,
           I had trouble doing mine at first.
Make sure the tensioner is fully backed off.
Make sure you are putting the chain back on from the left side of the cam as you are looking at it (exhaust ports in view).
In my experience the chain will not go back on from the other side.
Hope this helps.
Regards,
Offline WPF81S
« Reply #2 on: November 27, 2013, 01:46:05 PM »
Done it I just ignored the Haynes manual and used some common sense.
« Reply #3 on: November 27, 2013, 02:21:20 PM »
We should have a "Quote of the Month" page - I nominate this for the first inclusion"!
Steve
Offline LesterPiglet
  • 1977 CB550F2
« Reply #4 on: December 01, 2013, 03:46:18 PM »
I spent a while at mine until I decided to move the chain to the other side of the sprocket as I had tried everything else, much easier. :)
« Reply #5 on: December 01, 2013, 04:49:40 PM »
took me about an hour to realise that,
and when I fitted it it was 180 degrees out of crank,
luckily it was before and after a vacation,so when I returned,I sorted it before I turned the motor
Offline WPF81S
« Reply #6 on: December 02, 2013, 02:20:20 PM »
Yes very silly being able to fit a cam sprocket in 2 positions
Offline mickwinf
« Reply #7 on: December 02, 2013, 04:14:50 PM »
surely you can't get it 180 degrees out as long as crank is in correct position and cam notch lines up it cant be wrong?
« Reply #8 on: December 02, 2013, 05:01:38 PM »
 the problem was,I had lined the crank at TDC 1-4 ,and the cam notch at 3pm ish !!
but ,spent about an hour struggling to fit chain to sprocket,to shaft,during that time the crank got moved,mugs of tea
nearly got thrown across the garage,this at 9pm friday night,the day before going off on holiday,
it finally fitted,everything rotated as it should,no rockers fitted yet,
BUT !!
 while I was away,I gave it some thought,and decided to check the timing when I got back,
sure enough,it was well out,but,I remembered how to fit it quickly,so job done,properly
timed
and all back together,
only other assemble hassle is the airbox-cargs etc
dont want to either again in an hurry
Offline WPF81S
« Reply #9 on: December 12, 2013, 01:37:08 PM »
Put cam box back on and turned over engine by kickstart and am getting a load click see http://www.youtube.com/watch?v=NMbgar0vHqY&feature=youtu.be
« Reply #10 on: December 12, 2013, 01:43:46 PM »
Ian,
              Sounds like a sticking valve.
Have you had the guides done, I had this on my 400 4 valve sticks then the piston gives it a little tap and it snaps shut.
Could be wrong though.
Regards,
Offline WPF81S
« Reply #11 on: December 12, 2013, 03:05:32 PM »
No all this had done was head gasket also I have got huge valve clearences. It is not possible to put anything back together wrong is it?
« Reply #12 on: December 12, 2013, 05:18:21 PM »
Did you read the manual carefully about fitting the top cover as its very easy to bend valves if you don't
Offline WPF81S
« Reply #13 on: December 12, 2013, 07:35:57 PM »
I used elastic bands to hold the rockers up as I found a clip on youtube.
  • 1977 CB550F2
« Reply #14 on: December 12, 2013, 08:38:37 PM »
If you cannot adjust to the correct clearances something is not together properly, bent or broken.
