Other Stuff
Misc / Open
Engine painting
Topic: Engine painting (Read 7281 times)
boilermaker1
SOHC Associate
Engine painting
December 01, 2013, 07:51:54 PM »
Hi, I am restoring /tidying up my old 400 Four.
Bike is low mileage and engine runs very well.
I want to paint engine but do want to strip it down,
Engine is out of frame and sealed so was thinking
of either getting it soda blasted or vapour blasted.
Has any one painted their engine with out taking it apart
and got good results. View comments greatly appreciated.
RickyC83
SOHC Associate
Re: Engine painting
December 01, 2013, 09:04:40 PM »
I will be interested in any info on this to
billy192
SOHC Expert
Re: Engine painting
December 02, 2013, 05:19:37 PM »
Me too
Billy
cb750stu
SOHC Expert
Re: Engine painting
December 02, 2013, 06:01:44 PM »
Hi Guys,
I did my engine without taking apart all I took off to paint individually was the breather cover on top of the engine and the sprocket cover,
I Gunked my engine to get the worst of the grime off which worked very well
After that I gave it a good clean to remove the gunk residue then got to work with my Dremmel I ordered various dremmel bits but found the small wire brushes the best to get in between the fins in all it took me over a week just to prepare the engine for painting,
I made sure the engine was spotless before painting for paint I used Simonez paint spray which doesn't need primer or baking I masked off the finned part splines etc then did the silver first I gave it 4 coats with at least a day in between, this is how it turned out,
Last Edit: December 02, 2013, 08:33:50 PM by cb750stu
1976 CB750 F1 SS in bits !!! but getting there
RickyC83
SOHC Associate
Re: Engine painting
December 02, 2013, 10:30:37 PM »
Nice work dude that looks sweet
billy192
SOHC Expert
Re: Engine painting
December 03, 2013, 09:22:35 AM »
yes tip top
Billy
Billy
boilermaker1
SOHC Associate
Re: Engine painting
December 03, 2013, 05:56:11 PM »
Thanks for replying and posting photo's, Looks great
philward
Re: Engine painting
December 03, 2013, 07:36:17 PM »
I used silver hammerite smooth after degreasing and wire wooling. Havn't rebuilt bike totally so cant tell you how it performs but I got recommendation of a foram link. I'm really pleased with result.
Have tried to upload photo's but 'file too large' - Sorry
LesterPiglet
1977 CB550F2
Re: Engine painting
December 03, 2013, 11:12:24 PM »
re pics.
www.photobucket.com
Nerdos
Newbie
Re: Engine painting
December 04, 2013, 08:20:09 AM »
I saw a similar thread on the US site. In most cases I believe the paint has to be cured by heat. I discovered this to my cost when I did my 400Four (although I had the engine apart to paint it) and one of the carbs leaked on the top crankcase). Anyway, the American chap made an oven to cure his entire engine out of a large, baking-foil-lined box which he heated to about 90C or so with a hot air gun. He had some sort of thermometer in the top plus a removable flap to let heat out so that he could regulate the temperature. It looked a good idea and one I am toying with while the more meticulous part of me is urging a total engine strip and inspection. Hope this helps,
Paul.
And here's the link
http://forums.sohc4.net/index.php?topic=130303.0
Last Edit: December 04, 2013, 08:31:39 AM by Nerdos
bytio
SOHC Associate
Re: Engine painting
Reply #10 on:
December 05, 2013, 02:37:35 PM »
Worth looking at Stove Enamelling, I had my F2 satin black engine done, it's thin so no overheat problem fuel and oil resistant better than any other engine paint I have seen
bytio
SOHC Associate
Re: Engine painting
Reply #11 on:
December 05, 2013, 02:41:10 PM »
LesterPiglet
1977 CB550F2
Re: Engine painting
Reply #12 on:
December 07, 2013, 09:41:24 PM »
That looks well. Can you get silver stove?
RickyC83
SOHC Associate
Re: Engine painting
Reply #13 on:
December 07, 2013, 09:44:48 PM »
Dose tgat need to be in the oven so full strip right?
LesterPiglet
1977 CB550F2
Re: Engine painting
Reply #14 on:
December 07, 2013, 09:50:48 PM »
Yes it would...
Other Stuff
Misc / Open
Engine painting
