airbox assembly k3
Topic: airbox assembly k3 (Read 8160 times)
MIKE550/4
airbox assembly k3
January 06, 2014, 03:16:48 PM »
I have all the original parts but assembly is not happening for me
pics tonight once I have tried a few more times
anyone got a pic of their top of airbox for k3 by any chance
MIKE550/4
Re: airbox assembly k3
January 06, 2014, 06:30:28 PM »
Firstly I have read the manuals and I cant find nothing about these mounting plates
I have gone by the csmnl diagram but not convinced its right or maybe I have read it wrong
the left has a big spacer the right has a thinner one which goes through the air filter box
so guys enlighten me , the left even though tight still rattle about..... I have obviously got this wrong
Johnwebley
January 06, 2014, 07:10:25 PM »
thinks the short bracket is for carb side,longer bracket is rear wheel side !!!
how does the lower assembly fit ??
Ewan 500 K1
jings crivens help ma boab
January 06, 2014, 07:57:58 PM »
comparing the parts diagram with the photo it looks lilke you have number 14 on wrong Mike . Bolt should go through the hole at the foot of the longer side ... not the hole in the shorter side like you have it ?
500K1/550K3 mongrel cafe racer project for now at
http://www.sohc.co.uk/index.php/topic,4120.0.html
500K1 basket case for later
Piki
SOHC Expert
January 06, 2014, 08:35:16 PM »
Hey,tomorrow I Will go to mi Garage and I take pics from my 550 k3 for you.
MIKE550/4
January 06, 2014, 08:47:39 PM »
thanks piki appreciate that
just the top part of airbox and side shot should do
the manual photos not that clear on this section
Piki
SOHC Expert
January 06, 2014, 10:48:20 PM »
Look the number 15, his position is wrong, his position is on the bottom of the air filter box(look the diagram, there is a little hole) That piece is for fit the air box with the number 12.
Tomorrow more!!!
MIKE550/4
January 06, 2014, 11:02:56 PM »
i think I get it now
no 15 goes on inside of airbox
no 29 goes through plenum chamber , through the airbox and into no 15
would still like to see the pictures Piki to clarify
LesterPiglet
1977 CB550F2
January 07, 2014, 02:44:07 AM »
^^ That is correct.
Piki
SOHC Expert
January 08, 2014, 08:52:38 AM »
Hello Mike, look:
Subido en
subir imagenes
Subido en
subir imagenes
Subido en
subir imagenes
Subido en
subir imagenes
Subido en
subir imagenes
Trigger
Reply #10 on:
January 08, 2014, 09:06:31 AM »
Piki, in the last picture. Your breather element/condensation trap or what ever other people call it, isn't it up side down?. Nice clean bike.
Piki
SOHC Expert
Reply #11 on:
January 08, 2014, 11:32:59 AM »
Hi trigger, it is in the correct position!!!
Subido en
subir imagenes
MIKE550/4
Reply #12 on:
January 08, 2014, 12:14:32 PM »
Yeah that looks right, next part goes in upside down with spout pointing up
thanks for the photos
MIKE550/4
Reply #13 on:
January 08, 2014, 07:17:04 PM »
So after lots of input think I am there just need correct 18mm washer
if this is wrong I am fitting pods
Last Edit: January 08, 2014, 09:10:56 PM by MIKE550/4
MIKE550/4
Reply #14 on:
January 08, 2014, 08:01:20 PM »
its where the washer is now just wrong size fitted
18mm needed
Last Edit: January 08, 2014, 09:11:36 PM by MIKE550/4
airbox assembly k3
