CB750
K2 carb throttle spindle carrier.
Topic: K2 carb throttle spindle carrier. (Read 5771 times)
r1_pete
SOHC Member
June 06, 2014, 08:39:44 PM »
My carb throttle spindle carrier / mounting bracket is broken, on taking it to bits I find the 10mm shaft is running in a 13mm bore in the ally casting.
Before I go hunting for another casting, are there different sizes, or should there be a bushing in each of the casting lugs which the shaft runs in?
do these issues ever stop, I had less hassle with the E Type.....
Cheers.
Pete.
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
AshimotoK0
Mad Scientist.... more power Igor ! Ù©(̾à¹Ì®Ì®ÌƒÌ¾à¹ÌƒÌ¾)Û¶
Re: K2 carb throttle spindle carrier.
June 07, 2014, 07:56:43 AM »
Can you post a pic or P/N of what is broken Pete. I broke up a set of K2-K6 carbs to steal the floats/clips etc. from them for my K0.
Also have the alloy carrier for K7 carbs but that's totally different.
Cheers.... AshD
“Alright friends, you have seen the heavy groups, now you will see morning maniac music. Believe me, yeah. It’s a new dawn.†Grace Slick, Woodstock '69 .. In the year of the Sandcast.
r1_pete
SOHC Member
June 07, 2014, 10:52:02 AM »
Its the bit circled which has broken off on mine, I tried welding it, but the metal is like an aero chocolate bar and just will not weld neatly.
1971 CB450
mickwinf
June 07, 2014, 04:39:56 PM »
Pete if that is similar to the 500/550 type there was a pin that locates the shaft via a groove in the shaft itself, it stops side to side movement, usually gets broken when the shaft is forcibly removed (don't ask how I know
AshimotoK0
June 07, 2014, 05:46:23 PM »
I am pretty sure I have one of those spare Pete but may have spindles etc. still on it. It's no use to me as the 750K0 has 4 separate carb cables. I will have to venture in the garage which is chocker so give me a day to find it and I will send pic, if you are interested.
Cheers .. AshD
Last Edit: June 07, 2014, 05:48:15 PM by AshimotoK0
r1_pete
SOHC Member
June 07, 2014, 08:06:38 PM »
Yes please Ash, no rush, I'm not having much luck with this build, everything seems to be broken...
1971 CB450
AshimotoK0
June 08, 2014, 09:12:24 PM »
Wow must tidy that garage and get rid of the Midget!!!!
Here goes ... ones definitely off a '77 K7 (lower one in photo) and I think the top is K2-K6 but I will let you decide. Spindle nice and free on top one.
Cheers ...AshD
Last Edit: June 08, 2014, 09:15:06 PM by AshimotoK0
r1_pete
SOHC Member
June 10, 2014, 11:21:59 AM »
Cheers Ash, I have PM'd you.
1971 CB450
AshimotoK0
June 10, 2014, 10:06:30 PM »
No PM yet Pete
Cheers ... AshD
AshimotoK0
June 26, 2014, 12:22:01 PM »
Arranged shipping by MyHermes Pete to your daughters work.
Collection date Collected from Delivery to Weight Parcel no.
27/06/2014 HU3 2DJ S40 3QT 1 - 2 kg 9021373247153980 Track
Total (ex VAT) £3.32
Total VAT £0.66
Total (inc VAT) £3.98
Cheers ... AshD
CB750
