Author Topic: It has arrived!  (Read 60107 times)
Offline JustcallmeMrT
Re: It has arrived!
« Reply #45 on: September 09, 2014, 09:49:58 PM »
I've spent 3 weeks badgering the PO for those.  They are now safely in my possession and ready for a good clean!
Re: It has arrived!
« Reply #46 on: September 09, 2014, 09:52:12 PM »
Did you get the lever springs off him as well???
Re: It has arrived!
« Reply #47 on: September 09, 2014, 09:59:55 PM »
Indeed I did.  All parts seem to be there.  I can't say I wasn't worried.  Now all I still need to get from him is the original rear spoked wheel.
Re: It has arrived!
« Reply #48 on: September 09, 2014, 10:04:21 PM »
Not the nicest condition but I'm optimistic.
Re: It has arrived!
« Reply #49 on: September 09, 2014, 10:07:17 PM »
They will clean up nicely in a ultrasonic cleaner.
Re: It has arrived!
« Reply #50 on: September 09, 2014, 10:12:07 PM »
I have access to an small ultrasonic cleaning tank at work.  Any suggestions as to what type of cleaning fluid I should use to get these clean?
Re: It has arrived!
« Reply #51 on: September 09, 2014, 10:19:02 PM »
Just had a look at the one i use and it just says Ultrasonic Engine Part. Aluminum safe/ use between 50-80 degrees.
Re: It has arrived!
« Reply #52 on: September 09, 2014, 10:30:06 PM »
There is one on ebay with the same description, will give it a try.
Re: It has arrived!
« Reply #53 on: September 09, 2014, 10:36:25 PM »
I get mine from Woburn chemicals that is the nearest to me.
Offline tom400f
Re: It has arrived!
« Reply #54 on: September 10, 2014, 09:09:31 AM »
Are you paying for the bike in installments as well ?
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Re: It has arrived!
« Reply #55 on: September 10, 2014, 07:29:18 PM »
I wish I were....
Re: It has arrived!
« Reply #56 on: September 12, 2014, 11:25:44 PM »
Can anyone point me in the direction of a 'how to' for removing individual carbs from the assembly?  There looks to be more than just screws and bolts involved so figure I should do some homework.
Re: It has arrived!
« Reply #57 on: September 13, 2014, 09:22:00 PM »
Finally, some before and after shots!
Re: It has arrived!
« Reply #58 on: September 13, 2014, 09:40:38 PM »
You should of taken the tubes out before you put them in the tank. Why would you want to take the bank apart??
Offline matthewmosse
Re: It has arrived!
« Reply #59 on: September 13, 2014, 09:41:42 PM »
Inpressive. carbs are a swine to do, fiddly little things.
