Author Topic: cb 750 k4 swing arm bushings removal?  (Read 12446 times)
Offline antonypo
  • wheres the breaks on these cb 750's !
« on: January 09, 2015, 02:34:20 PM »
Well i,m really pleased with the results on the front forks. All finished now and onto the swing arm
. I have new bushings , bearings, dust seals etc but how do I remove the old bushings?
 Also how do I remove the old bearings.
Antony
Re: cb 750 k4 swing arm bushings removal?
« Reply #1 on: January 09, 2015, 03:08:33 PM »
Anthony
The easiest way is knock the steel pin that,s almost as wide as the arm out then junior hacksaw blade cut grove then crush the bush making sure you don't cut into the arm.When you replace put 1 bush in then insert the long collar then fit the other bush and grease all well.Does that make sense to you? ;)
Bitsa
« Reply #2 on: January 09, 2015, 03:34:21 PM »
Went through this a couple of weeks ago >  http://www.sohc.co.uk/index.php/topic,7574.0.html
Offline antonypo
« Reply #3 on: January 09, 2015, 06:32:26 PM »
Thanks for the info Bitsa.
 Just to confirm on the bearings for the shocks Trigger - they are tapered so should be pushed in with a socket not out??
Antony
« Reply #4 on: January 09, 2015, 06:49:06 PM »
Dont know NEVER EVER REPLACED THESE why are you lot finding them so knackered? :o
Bitsa
Offline antonypo
« Reply #5 on: January 09, 2015, 07:02:03 PM »
There was a lot of play in the swing arm before I dismantled it. To be honest I am replacing the shock bearings because I have new shocks and thought it best.
Antony
« Reply #6 on: January 09, 2015, 07:14:23 PM »
Bitsa
Because fat arse frenchman had owned them before ;D ;D I have only ever changed about ten sets in my life time.
« Reply #7 on: January 09, 2015, 08:22:13 PM »
Well you old git 10 in yer lifetime aint bad is it? ;)Fit the unit and any up and down tells you all
Bitsa
Offline antonypo
« Reply #8 on: January 11, 2015, 01:23:29 PM »
I have removed the old bushes from the swing to fit new ones for the rear shocks but they would not fit. I then thought there was still a outer shell which needs to come out but as I started sawing through I thought id better confirm with you its the correct thing to do. Please advise me.
Secimd pic is what im attempting to do.
Antony
Offline Green1
« Reply #9 on: January 11, 2015, 03:11:49 PM »
Yep looks like part of the bush is still in there
Mick
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline antonypo
« Reply #10 on: January 11, 2015, 03:48:29 PM »
Thanks Mick. You gave me the courage to carry on. All done now. See pic.  A few things though :-
The originals had a rubber membrane which I assume aided the damping but these new ones do not. Any idea why?
Secondly and lastly - I bought new bushes for the swing arm at the front which I thought would be plastic - as mentioned elsewhere  - but there not. They do not appear to be worn and look as good as new even though I thought their was play there isn't. It must have been loose in the frame when I tried. Anyway I know the method with a threaded bar to remove these but I do not possess one.
It might take some effort and banging to remove the old ones. As the arm is already powder coated is it worth the effort on a 40k usa bike when all appears to be well?
Antony
« Reply #11 on: January 11, 2015, 03:52:08 PM »
The collar, which is eexpensive, normally wears more than the bushes--check that carefully for wear
Offline Green1
« Reply #12 on: January 11, 2015, 03:57:28 PM »
Yep the collar wears quit badly if not greased often I do mine every thousand miles.
If there's no play in the bushes I would leave them.
Mick
Current bikes
Triumph tiger 800
Aprilia Pegaso 650
Kawasaki ZXR400 J
« Reply #13 on: January 11, 2015, 04:09:55 PM »
If by the collar you are refering to the phlange bit that sits on the outside top of the bush, how would I get in there to grease mine without taking the swing arm out of my 400?. I have got a grease nipple that takes grease along between the shaft and the spindle but the grease can't get to the top of the bushes. Having just fitted my nice new brass bushes, I don't want the ends wearing thin  :'( :'(
« Reply #14 on: January 11, 2015, 04:46:07 PM »
That's why we soak phosphour bronze bushes overnight in oil before fitting them:)) because the grease from the single nipple takes a long time to reach the bushes, so oiling them first saves a lot of problems later on. The collar Bryan was referring to is the metal sleeve that fits inside the bushes with the pivot passing through it, so nothing to do with your flanges dear girl:))
