Author Topic: Nearly There CB750K2  (Read 34272 times)
Re: Nearly There CB750K2
« Reply #60 on: January 11, 2015, 09:17:06 PM »
Yep that's the one - if it was 3/4, then that will make it rich I guess? May explain why no choke required?
« Reply #61 on: January 11, 2015, 09:19:58 PM »
The more the air screw comes out, the more air is mixed  ;)
« Reply #62 on: January 11, 2015, 09:27:18 PM »
Got to put guages on (too late now - don't want too wake neighbours kids!) But tick over steady cold without choke - revs fine. Clutch really noisy until I pull in clutch (may be carbs out of balance?) - everything in clutch is new except basket
« Reply #63 on: January 11, 2015, 09:28:30 PM »
Last message is with 1 1/8 airscrew by the way
« Reply #64 on: January 11, 2015, 09:33:21 PM »
These clutches are known to be noisy but, i don't know how noisy your is.
You can go to 1 1/4 on the screw if it is still rich.
« Reply #65 on: January 11, 2015, 09:36:16 PM »
Graham
what's your thoughts on not needing choke?
« Reply #66 on: January 11, 2015, 09:44:28 PM »
You need to get the carbs set up and it strobed. Maybe the carb slide are too high.
« Reply #67 on: January 11, 2015, 09:53:55 PM »
That's my next job then - any links to carb section of a manual (as I said, only got manual for early 4 cable)
« Reply #68 on: January 11, 2015, 10:07:08 PM »
You have got me there because i don't use manual's. I bench synchronize them and once on, then vacuum gauge them up. You will have to search.
« Reply #69 on: January 11, 2015, 10:16:17 PM »
Thanks Graham - its not the mechanics of carbs I need (had them in a thousand bits for zincing/etc) but more the settings info - its 30 years since I set the old 4's up.
Thanks again
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #70 on: January 11, 2015, 11:41:24 PM »
Hi Phil,
From my manual, this posting in due parts due # of pics. The manual is basic K0, with supplements for K2-K4.
These pics are for the initial (K2) set up... and yup, apologies for the quality but work from an iPad..
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #71 on: January 11, 2015, 11:47:14 PM »
.... and the rest of them...
Hope you can read it all (sorry)
Simon
« Reply #72 on: January 12, 2015, 07:31:07 PM »
Thanks Lobo - much appreciated
« Reply #73 on: January 12, 2015, 07:44:45 PM »
It don't stop still frackin about after 4 years some days runs 100 percent next week farts and fracs about then real fine and so on.Cant wait to test ride my next one in the garage starts perfect runs great but until you go out and give it some you don't know but I will not be beaten
Best of luck
Bitsa
« Reply #74 on: January 12, 2015, 09:04:56 PM »
Bitsa
I'm a bit away from test riding - just made up it run straight away. When every part has been to bits (particularly carbs for zinc plating), just relieved it started! I'm ahead of schedule anyway as geared up for spring test/MOT but hopefully will be sooner.
Will mess again at weekend
