Project Board
f2cafe racer
18
19
20
21
29
Topic: f2cafe racer (Read 131657 times)
yozzer74
Re: f2cafe racer
Reply #270 on:
February 23, 2016, 10:11:39 PM »
Thanks for comments appreciate it
Pops400
SOHC Member
I haven't a clue what I'm doing...
Re: f2cafe racer
Reply #271 on:
February 25, 2016, 09:23:29 AM »
Mmmmmm.... Shiny...
Looking fantastic.
And if I claim to be a wise man, it surely means that I don't know.
UK Pete
Re: f2cafe racer
Reply #272 on:
February 25, 2016, 04:40:35 PM »
Bloody amazing yozzer a really nice build
I have two cafe racers waiting to be done some of my parts are the same as yours like the adjustable clip ons
pete
Link to my Diecast K0 restoration
http://www.sohc.co.uk/index.php/topic,4827.0.html
Link to sandcast restoration
http://www.sohc.co.uk/index.php/topic,6862.0.html
yozzer74
Re: f2cafe racer
Reply #273 on:
February 27, 2016, 08:18:17 PM »
Thanks Pete .you will have to get cracking on the cafe builds .Well I got a little bit more done today .made some oil pipes up .and got the carbs out I've been dreading this part with all the bad things ive read about these carbs .does anyone no of any links were people have stripped the carbs totally down .separated the bank .think I'm going to have them vapour blasted first . [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
yozzer74
Re: f2cafe racer
Reply #274 on:
February 27, 2016, 08:26:32 PM »
Carbs [ Guests cannot view attachments ]
yozzer74
Re: f2cafe racer
Reply #275 on:
February 28, 2016, 05:43:38 PM »
Sanded Honda emblem down on calipers then polished them up . [ Guests cannot view attachments ]
yozzer74
Re: f2cafe racer
Reply #276 on:
March 03, 2016, 05:57:00 PM »
Think I've dropped a b####k having carbs vapour blasted they are now full of little glass beads .but they do look clean .there going to need a full strip down which is a job I didn't want to do
yozzer74
Re: f2cafe racer
Reply #277 on:
March 03, 2016, 06:40:47 PM »
Carbs [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
royhall
Keep biking I'm not quite bankrupt yet
Re: f2cafe racer
Reply #278 on:
March 04, 2016, 06:45:43 AM »
There's a guy in Holland called Gerben Van Der Mere that does a cracking carb rebuild at reasonable cost. Those PD carbs are a sod to do. Surprised the vapour blaster didn't advise you to strip them first, as now all your springs and linkages will rust like crazy. I had mine done and they came out like new, 6 months later they look like they were never done. Back to the standard dull grey finish. I would post them off to Gerben.
Sent from my Nexus 6 using Tapatalk
Last Edit: March 04, 2016, 06:47:30 AM by royhall
UK Pete
Re: f2cafe racer
Reply #279 on:
March 04, 2016, 07:07:08 AM »
Hey yozzer, think logically the F2 carbs are a pig, but when the bikes left the factory they were fit for purpose so , it should be achievable getting them correct, the fuel pump and its jets need the most attention, there are little one way valves that get stuck and the very fine jets that squirt the fuel get blocked real easy , you can take them out and put a fine wire brush hair to clear them, once you have built them fill them with fuel on the bench and make sure each jet is spraying, cause that causes the throttle delay, the rest is the same as any other carb, however when these carbs were new they were a pig at warm up simply cause they were made to run lean, you have to piss around with the chock for a while till it hot that is normal
pete
yozzer74
Re: f2cafe racer
Reply #280 on:
March 13, 2016, 09:08:24 PM »
Fitted my exhaust but when it's tightened up it touches the sump.any ideas how to solve problem I will get some pics on tomorrow of it .
yozzer74
Re: f2cafe racer
Reply #281 on:
March 14, 2016, 04:13:10 PM »
Some pictures of how close exhaust is think I'm going to after make a bracket to hold it off the engine . [ Guests cannot view attachments ] [ Guests cannot view attachments ]
UK Pete
Re: f2cafe racer
Reply #282 on:
March 14, 2016, 06:12:40 PM »
Crikey thats tight, could of done with another 10mm of clearance, pushing it down with a rear bracket might just do it, however you dont want to stress it too much incase it cracks over time
yozzer74
Re: f2cafe racer
Reply #283 on:
March 14, 2016, 06:15:57 PM »
Yeah that's a problem I've been in touch with carpy who I got it off .is answer to it was shave the fins off the sump .not good
UK Pete
Re: f2cafe racer
Reply #284 on:
March 14, 2016, 06:19:52 PM »
Thats not a bad idea, sumps are quite cheap, its the wrong answer from the seller though, he should check the rest of his stock before selling more, and possibly offer a bit of discount for your troubles
18
19
20
21
29
Project Board
f2cafe racer
