Author Topic: CB550 Cylinder Head Oil Seals + Nuts  (Read 8146 times)
Offline sam_vfr
« on: March 03, 2015, 12:46:36 PM »
Hi All
New to the forum and just in the process of rebuilding my 550 engine.
Does anyone know were to get the cylinder head oil seals from + what nuts are require for the cylinder head itself?
Any help would be greatly appreciated.
Sam
Re: CB550 Cylinder Head Oil Seals + Nuts
« Reply #1 on: March 03, 2015, 01:28:29 PM »
What seals, they are all "O" rings and should be in a gasket set, the nuts are flanged with a 12 mm hex so need to be genuine Honda they also have a thick washer under them
Offline sam_vfr
« Reply #2 on: March 03, 2015, 03:00:19 PM »
Hi Bryanj
Thanks for the reply.  These are the ones under the valve cover.  You have to remove them to get to the head bolts.
Were would you get the head bolts from.  Only place i really know is David Silver spares but i cant seem to find them listed.
Sam
Offline Drew400
  • 400/4 I restored
« Reply #3 on: March 03, 2015, 03:17:56 PM »
Hi Sam & welcome,
It's often best to call DSS on 01728 833020 rather than relyng solely on their website.
Cheers,
D.
Offline mickwinf
« Reply #4 on: March 03, 2015, 03:23:10 PM »
Hi Sam are you asking about the rubber "pucks" the flat rubber seals over the holes above the main head studs, 6 required part number 91318-300-013, the nuts are 90236-300-000 12 required, and the thick washers 90485-035-000 12 required.
« Reply #5 on: March 03, 2015, 08:11:21 PM »
Copy and paste the following into ebay
M8x1.25 12mm Hex Head Smooth Metric Flange Nut Cylinder Frame Ahrma Elsinore
« Reply #6 on: March 04, 2015, 08:15:13 AM »
A "decent" gasket set has those rubber dokikies in it, not being a yank i refuse to call them Pucks but will admit to Pontefract cakes
« Reply #7 on: March 04, 2015, 09:03:23 AM »
hard to find these in the UK and you cant use stainless steel
« Reply #8 on: March 04, 2015, 10:21:53 AM »
There's someone on ebay, following that link that does BZP
« Reply #9 on: March 04, 2015, 07:23:00 PM »
Me too WTF is a puck?
Bitsa
« Reply #10 on: March 05, 2015, 06:50:22 AM »
Either a character in shakespeare or summat that gets twatted about at high speed in ice hockey
« Reply #11 on: March 05, 2015, 09:34:38 AM »
 ;D ;D ;D ;D
Bitsa
