Author Topic: Horn mounting clip  (Read 8768 times)
Offline Myford
Horn mounting clip
« on: July 19, 2015, 04:35:39 PM »
That little chrome clip on the horn bracket is driving me potty. Can anyone explain how its meant to fit, or ideally post a picture please. The horn faces sideways, and I'd always assumed that the clip faced upwards and towards the frame to hold the throttle cables, but then I read on here somewhere that it goes the otherway round and holds the tacho cable in.
I must have spent an hour this morning pratting around with it, and I'm still none the  wiser.
Terry
Offline Chris400F
Re: Horn mounting clip
« Reply #1 on: July 19, 2015, 05:51:18 PM »
Terry,
Not the best picture in the world - access is limited with the tank in place - but hopefully this will give an idea of mounting.
Chris
Offline Myford
« Reply #2 on: July 19, 2015, 06:43:24 PM »
Chris
So the clip is on the rearmost bolt, and it's facing the spine frame tube and it's holding the throttle cables and the tacho cables against the frame. Have I got that right?
Terry
Offline Chris400F
« Reply #3 on: July 19, 2015, 10:33:26 PM »
Terry,
It is on the rearmost bolt. Clip keeps throttle cables and clutch cable in place, not the tacho.
This topic has a link to the dealer setup manual, page 16 shows what you are looking for:
http://www.sohc.co.uk/index.php/topic,8234.msg54250.html#msg54250
Chris
Offline Lobo
  • Lobo
  • Lobo
    • Lobo
« Reply #4 on: July 20, 2015, 01:37:04 AM »
Hmm.. thanks guys think I've got mine mounted to the wrong bolt.  Nonetheless, basic idea here. Note tho' the tachometer cable is just never going to 'fit in'
Lobo
« Last Edit: July 20, 2015, 01:42:44 AM by Lobo »
Offline Chris400F
« Reply #5 on: July 20, 2015, 09:23:12 AM »
I have just looked at the diagram in the setup manual again and now I am confused, as it shows the clip mounted to the front bolt.
As a 9000 mile bike I don't know that it would ever have been apart, but that doesn't mean it was 'right' in the first place.
Without taking the tank off I can't have a better look I'm afraid, although I'm sure it will do the job intended whichever bolt it is mounted to.
As previously noted, the clip holds the throttle cables and clutch cable in place, not the tacho.
Offline Myford
« Reply #6 on: July 20, 2015, 07:24:56 PM »
I had it on the rear bolt to start with, but reading an old topic titled Coils/leads (sorry can't do the clever link) it suggested to me that the clip included the tacho cable, that's what was driving me potty trying to figure  out how it could possibly hold the tacho cable.
Thanks for the help guys. now for my next topic  ....... coils.
Terry
Offline tom400f
« Reply #7 on: July 20, 2015, 09:27:40 PM »
OK so it's the front bolt and mine is, amazingly, wrong but I have removed it before so my fault.
Another 400F discussion on forensic detail  ::)
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Offline steven400/4
« Reply #8 on: July 20, 2015, 10:02:21 PM »
front bolt offside of the bike throttle cables but i,ve never had taco cable in it before just in the ring on the breather its the same on all four of my bikes
cb400f2 x7
honda ss 50
gsx 1400
Offline tom400f
« Reply #9 on: July 20, 2015, 10:04:25 PM »
That's the clutch cable Steve  ;)
Anyway, glad I didn't mislay the clip. Heard they are a fortune to replace  8)
1978 CB400F2 Yellow
Offline Chris400F
« Reply #10 on: July 21, 2015, 11:30:47 AM »
Just answering the question asked with the information I have available ....  :)
As I said, I'm sure it will do the job intended whichever bolt it is mounted to.
Probably not cheap to replace (if you can find one), but what is?
Same clip apparently also used on XL250 and 350.
