Author Topic: Engine teardown and inspection  (Read 16402 times)
Re: Engine teardown and inspection
« Reply #60 on: November 21, 2020, 06:37:16 PM »
Nice work cantarauk, also one of the most enjoyable parts of rebuild after all the cleaning etc.
Offline cantarauk
« Reply #61 on: November 21, 2020, 06:47:10 PM »
Conrods cleaned with new shell bearings that were measured to match the crankshaft specifications.
Crankshaft was sent off to machine shop to be measure and balanced. New crankcase shells that were matched to the work the machine shop did in meeting the required specifications. Crankshaft cleaned and then greased well before returned to me.
To the left on the image new Cam Chain and Primary chain
New shells about to go in
Offline cantarauk
« Reply #62 on: November 21, 2020, 06:48:05 PM »
Thank you K2-K6. Taking my time as loads of reading to do to be sure I don't screw anything up
« Last Edit: November 21, 2020, 06:50:22 PM by cantarauk »
« Reply #63 on: November 21, 2020, 07:00:37 PM »
All looks nice and clean.
Offline cantarauk
« Reply #64 on: November 21, 2020, 07:08:17 PM »
New shells inserted fully
Camchain and Primary Chain fed onto the Crankshaft and in position with the crankshaft dropped into the top case
Oil seals for both sides of the crankshaft
Conrods connected, bolted up and nuts torqued down to 2.0 Kg-Meter
Top view of it all nice and snug in the case
« Reply #65 on: November 22, 2020, 01:16:56 AM »
Not sure what you have on the back of the shells but, they should be dry to the case and rods  ;)
Offline Skoti
« Reply #66 on: November 22, 2020, 09:36:28 AM »
Nice job and great photos,
I've never seen the crank journals greased up like that before assembly, is that standard practice?
I normally just oil them lightly.
Good luck with the rebuild
Skoti.
Skoti
1976 Honda CB750F1
Offline cantarauk
« Reply #67 on: November 22, 2020, 01:33:54 PM »
Tigger metal on metal got it. Will clean and re-seat the shells
Skoti - Cheers. The crank and conrods both came back like that from the machine shop covered in grease and to be honest I too quiet a bit off before connecting up and dropping in.
This is what it came back like - Crankshaft was covered thicker
Offline philward
« Reply #68 on: November 22, 2020, 02:04:20 PM »
Skoti.
Most of the experts on here recommend using Grafogen (proberly spelt wrong!) as an assembly grease - to ensure pre oil pressure lubrication of metal to metal surfaces such as big ends, mains, cam journals, etc.
Offline cantarauk
« Reply #69 on: November 22, 2020, 09:52:14 PM »
Need three things checking please as I hope some of these are correct but could do with a Jedi/Expert opinion to validate.
For the Countershaft assembly No 19 and No 20 on the image is the way I put these washer back correct
The way I put these back below but I am more interest in washer 20 to see if the turned pieces went in the correct way. No 19 I assumed is the flat washer and No No 20 the washer that has bent ears for the I/D piece.
The second thing I need checking is with the Mainshaft when I stripped it down there were 2 washers where No 18 is.
I started putting this back without the second washer. Below is what I found when I stripped the Main shaft down for cleaning.
The 3rd query is reading the Haynes manual when inserting the second drive it says - " Ensure that a new oil seal has been fitted to the secondary drive sprocket end of the layshaft and that a new O ring positioned behind the oil spacer" From the parts images above I can't see this O ring only the one that fits between the bearing and the fixed positioner on the mainshaft No 3.
page where I read this added below -
I did not remove the bearing No 22 all the way to No 7 only No 19 to No 24 for cleaning. So assume O ring No 27 is still there
« Last Edit: November 26, 2020, 09:21:02 AM by cantarauk »
Offline Skoti
« Reply #70 on: November 23, 2020, 08:42:06 AM »
Skoti.
Phil,
thanks for the Graphogen tip, it's something we never used or had in the seventies when I worked in a Honda franchise. Although I remember using something similar during the eighties in the motor trade whilst renewing MK1 Astra camshafts.
As ever I'm always learning new stuff from the posts and fantastic photo documented rebuilds on this website.
Regards
Skoti
Skoti
1976 Honda CB750F1
« Reply #71 on: November 23, 2020, 09:49:16 AM »
I was delivering car perts when the Astra/Cavalier had the cam troubles and every dealer was waiting for camshaft/follower sets.
There used to be a proceedure for first start up, something like 3 minutes at 4000 rpm followed by 2 minutes at 2000 rpm before you let it tick over. Something to do with oil flow quantity
Offline cantarauk
« Reply #72 on: November 26, 2020, 01:26:50 PM »
Any comments to the post on 22nd about washer an o-ring question
« Reply #73 on: November 26, 2020, 03:57:00 PM »
Would it be part 27
Offline cantarauk
« Reply #74 on: November 26, 2020, 04:08:50 PM »
Bryan,
Thinking about again it must be as the spacer is the bearing looking think attached to the shaft itself. Now I never removed all the gears on that shaft as I could not figure out how to get No 7 off. Would it be best to try again and replace the o-ring or would I be good with that one.
Also any view on the extra washer that was on mainshaft ?
