Author Topic: rotor removal tool. Also Gaskets  (Read 267 times)
Offline Eldrick
« on: May 14, 2024, 03:29:27 PM »
When I replace the alternator later this week is it best to have a rotor removal tool?
I also need to replace, at least, the rocker cover gasket and maybe the cylinder head gasket, not sure yet where the main leak is. From which supplier will I get the best quality gasket set please?
1975 Honda CB400f - Red
Re: rotor removal tool. Also Gaskets
« Reply #1 on: May 14, 2024, 04:02:24 PM »
Why do you need to replace the generator they rarely fail
If you do no the rotor does not need to come off
Head gasket can be done with engine in, there are not a lot of options for sets now but you will need the special sealing washers under some of the head nuts
Offline Eldrick
« Reply #2 on: May 14, 2024, 04:27:56 PM »
Bike 'broke down' two days ago. Battery was not charging when I went on a run two days ago. It is a new battery and I recently replaced the wiring loom. I can't for sure rule out the rectifier or regulator however the AA man, (a biker too, he used to build custom machies for himself) strongly suggested the issue is insufficient charge from the [/color]alternator. [/size]
Offline Jan B
  • Everything you can leave behind is a gain
« Reply #3 on: May 14, 2024, 06:10:13 PM »
Did you check the ohm-readings on the 3 stator wires? That will tell you something. The regulator is more likely to fail...
CB500K1
CB750K2 [project]
BMW F800GS
« Reply #4 on: May 14, 2024, 06:24:31 PM »
I would also add you can get corrosion in the output connection block as well as where it leaves the alternator housing.
« Reply #5 on: May 14, 2024, 08:53:56 PM »
The least common no charge is the generator,
Most common is bad connection
Next is regulator, especially electronic ones
Offline Eldrick
« Reply #6 on: May 14, 2024, 09:23:12 PM »
I will google how to do that
