Author Topic: Indicator fault  (Read 6655 times)
Offline davidrsmith
Indicator fault
« on: September 28, 2016, 08:49:10 PM »
Hi
Now got the carbs fitted (thanks for the help) I have fitted the airbox and the battery. I have tried turning the electrics on for the first time, all seems ok except the indicators. Moving the switch to either left or right just gives me a loud screeching noise, the bulbs don't light and I can't hear the relay at all.
Anyone ever seen this, I haven't had a chance to fault find on it yet but I guess either the relay is shot or there is a short?
Dave
Re: Indicator fault
« Reply #1 on: September 29, 2016, 06:20:28 AM »
The screech could be the relay if there is a short or could be the audible device depending on what bike
Offline davidrsmith
Re: Indicator fault
« Reply #2 on: September 29, 2016, 06:33:43 AM »
Hi
The bike is a CB550k3 which was imported from the US. So it was built to their standards, on the circuit diagram in the haynes manual it does show a turn signal buzzer, but I haven't actually seen it (not that i've looked) on the bike.
Dave
Re: Indicator fault
« Reply #3 on: September 29, 2016, 07:27:15 AM »
May not be related, but it's good practice to run a separate earth cable to each of the indicators. Sounds like the flasher relay has gone, and take the opportunity to remove the awful buzzer.
Offline mike the bike
Re: Indicator fault
« Reply #4 on: September 29, 2016, 07:31:09 AM »
Agree 100% with the above advice.
Offline davidrsmith
Re: Indicator fault
« Reply #5 on: September 29, 2016, 07:13:25 PM »
Thanks for the replies, where is this buzzer located on the CB550k3,  I must admit I haven't noticed it?
Offline davidrsmith
Re: Indicator fault
« Reply #6 on: September 29, 2016, 08:43:34 PM »
Fixed, it was the buzzer, as soon as I removed it the indicators started working.
Thanks for the advice.
Offline Rob.b (Rob Birkett - RIP)
Re: Indicator fault
« Reply #7 on: September 29, 2016, 08:59:32 PM »
LMAO, must only be me that likes that buzzer. I still have it fitted to one of my 500s.
Ha ! No you are not alone, I've put one on my CB500 I would not be without it.
Rob.
Re: Indicator fault
« Reply #8 on: September 30, 2016, 07:00:53 AM »
But honda asked the dealers to remove them as they sounded too much like crossing beepers to the blind!!
Offline D C 500
Re: Indicator fault
« Reply #9 on: October 02, 2016, 10:43:33 AM »
Rob.
Same here, sounds like a dust cart reversing when applying the indicators. with my memory i need it.
Offline Ashdowner
Re: Indicator fault
« Reply #10 on: October 08, 2016, 02:21:09 PM »
My CB550K3 came with the original buzzer removed so I put an aftermarket one on which isn't too obtrusive. I also changed the indicators to led's and got an led relay at (total cost £10) and that was one of the steps which solved my charging problems (the others being a Phillips Eco H4 bulb and an led stop/tail)
Offline Moorey
Re: Indicator fault
« Reply #11 on: October 09, 2016, 09:47:26 PM »
+1 for the buzzer mine sounds like a strangled cat. I wouldn't be without it :D
