Author Topic: F2 barrels  (Read 2952 times)
Offline yozzer74
F2 barrels
« on: November 26, 2016, 08:52:08 PM »
Hi quick question can you use any barrels on a f2 or do they have there own barrels
Offline Phil Ward (RIP)
Re: F2 barrels
« Reply #1 on: November 26, 2016, 09:42:17 PM »
I think K5 onwards will fit - they seem to have the 8 x 12mm knock pins/seals like the the later F1/2 but I'm sure I'll be corrected by Trig and other more knowledgeable members if thats not correct
Re: F2 barrels
« Reply #2 on: November 26, 2016, 09:52:26 PM »
Never really studied the F2, I know that the part number is different but, I would not know why.
Re: F2 barrels
« Reply #3 on: November 26, 2016, 09:56:06 PM »
Could it be a different part number because of colour - the F2 had a black barrel - or is that too simplistic1
Re: F2 barrels
« Reply #4 on: November 26, 2016, 09:59:06 PM »
That is too simple Phil, if it was just colour the difference would be in the last 3 numbers and not the middle 3 ;)
Re: F2 barrels
« Reply #5 on: November 26, 2016, 10:33:00 PM »
Isnt the oil feed/return path from the rockers different on the F2, hence the domed head nuts and copper washers
Re: F2 barrels
« Reply #6 on: November 27, 2016, 10:43:57 AM »
Found this in my notes from the US site
First, the 77/78F2/3 heads shared a common head drain back hole which early K,F and late K heads did not.
This eliminated the middle drain back holes in the F2/3 heads.
The 4 studs next to the eliminated drain back holes require cap nuts and copper sealing washers on the F2/3 head only.
The late F2/3, 77/78 cylinders CAN accommodate the knock pins(or dowels) and the rubber gaskets which allows you to run these early/late K and earlyF/F1(75/76) heads.
Here's the full article which also goes into using K barrels with an F2 head
http://forums.sohc4.net/index.php?topic=99165.msg1105716#msg1105716
« Last Edit: November 27, 2016, 02:57:49 PM by Spitfire »
Greebo
  • Guest
Re: F2 barrels
« Reply #7 on: November 27, 2016, 10:58:19 AM »
 Steve or Pete are the 2 men to answer this one ...
