Author Topic: Front brakes sticky (dual disc)  (Read 5467 times)
Offline El__burro
« on: April 28, 2017, 02:46:19 PM »
Good day, i am trying to get the brakes do a good working order.
I have realised that the pads are sticking to the disc on the RHS. After playing with the bolt to distance the calliper i have realised that the IN and OUY oil pipes are not on the same order. Does this matter?
el__burro
Sent from my SM-G935F using Tapatalk
Offline hairygit
Re: Front brakes sticky (dual disc)
« Reply #1 on: April 28, 2017, 03:36:03 PM »
No, it won't matter, it's because the caliper on the right leg is the same as the left, therefore the pipe/bleed nipple positions are reversed. Is the right hand caliper mounting EXACTLY parallel to the disc? Some brackets need spacing with shims/washers to make them parallel.
« Reply #2 on: April 28, 2017, 05:44:55 PM »
Did you rebuild both calipers and are the flexibles new?
Offline El__burro
« Reply #3 on: April 28, 2017, 06:34:56 PM »
Ok, yes, calliper are recently rebuilt, flexibles have been flushed and in good condition. It used to be great. I'll try different options. Thanks
el__burro
Offline neilg
« Reply #4 on: April 28, 2017, 07:44:01 PM »
Does the right hand caliper actually line up properly. Honda machine the left side fork leg to suit but leave the right side untouched so it possibly is not in line.
Offline El__burro
« Reply #5 on: April 28, 2017, 09:01:45 PM »
The problem is that when I pull the brake, it brakes lovely unfortunately it stays locked. I guess I need to dismantle the calliper.
el__burro
« Reply #6 on: April 28, 2017, 11:20:37 PM »
That could be the tiny hole in the master cylinder blocking
Offline neilg
« Reply #7 on: April 29, 2017, 02:55:01 PM »
Wouldnt that affect both sides though??
« Reply #8 on: April 29, 2017, 03:23:23 PM »
 In theory yes but in theory a bee can't fly! When it sticks try loosening the bleed nipple and see if it frees off
Offline MarkCR750
« Reply #9 on: April 29, 2017, 05:51:46 PM »
Also take the calipers off (it's only 2 bolts per calliper) and have a look around the pistons for signs of corrosion or a build up of dirt, whilst the calliper are off check that the brake arms (the arms that the callipers are mounted on) move freely on their pivots.
Triumph Scrambler 1200X
CCM 604 dual sport
1977 K7 CR750
Ducati 900SS
James Captain 197 x2
Norman Nippy 50cc
Sir J.Stewart.
Offline mike the bike
« Reply #10 on: April 29, 2017, 06:39:44 PM »
Have you replaced that square section seal in the caliper - the one the seals against the piston?
I read on this here forum somewhere that that seal can cause the piston to stick if it's worn.
Offline El__burro
« Reply #11 on: May 03, 2017, 10:54:29 PM »
What did you use to hold the calliper arm on the right hand side? The spring like the one on the left will not work..
el__burro
« Reply #12 on: May 03, 2017, 11:23:50 PM »
el__burro
 the spring is not essential,you can adjust the arms,as long as the pad faces are parrallel  to the disc,
Offline Phil Ward (RIP)
« Reply #13 on: May 04, 2017, 06:44:09 PM »
I used these - http://www.ebay.co.uk/itm/1-5mm-Helical-Compression-Springs-zinc-DIN2095-x-25mm-to-100mm-long-deals-/331752550229?var=&hash=item0
Don't forget that the spring will be longer than the L/H spring due to the fork leg lug being in a different position
