Speedo.
Topic: Speedo. (Read 5229 times)
heliwilly
SOHC Member
Speedo.
May 24, 2019, 10:53:54 PM »
Hi All,
Just taken the screw and bolt out of the speedo take off point on the rocker cover. You've guessed, its broken and has been for some time. Does anyone have the part Number and a possible source to get one from? TIA Bill W.
Trigger
Engines built on reputation, not advertising.
Re: Speedo.
May 25, 2019, 06:39:00 AM »
These get broken when someone uses a impact on the JIS screw to try to get them out. Now Bill, are you sitting down with a big stiff drink >>>>
https://www.davidsilverspares.co.uk/CB550F2-SUPER-SPORT-1977/part_176188/
Its not a speedo, its a tacho drive
Last Edit: May 25, 2019, 06:45:04 AM by Trigger
matthewmosse
Re: Speedo.
May 25, 2019, 08:18:29 AM »
Ouch! Those cost nearly what I was used to paying for a scrap engine. Surely it's possible to weld the tang back on and grind the weld back to profile? These bikes used to be cheap to run.
heliwilly
SOHC Member
Re: Speedo.
May 25, 2019, 11:31:11 AM »
Hi Trigger,
As you rightly say it is the Tacho take off from the Rocker cover. Speedo from front hub.
They are quite pricey (picks self up from floor)
Bill.
matthewmosse
Re: Speedo.
May 25, 2019, 01:22:34 PM »
I know I have at least 1 spare that's in completely the wrong shed for bike bits, I keep seeing it when I dont want it but then forgetting where it is when I want it.
heliwilly
SOHC Member
Re: Speedo.
May 25, 2019, 03:12:38 PM »
Hi Oddjob,
Yes, it is the lug that is broken where the JIS Screw goes through. Looks like it has been over tightened.
If you can find where you put the one you have seen, I would gladly have it off you, no real rush, this is a long term project.
If anyone else finds one, let me know.
Bill W.
heliwilly
SOHC Member
Re: Speedo.
June 26, 2019, 03:06:49 PM »
Hi All,
Still looking for the Tacho take off point that bolts and screws to the rocker cover.
Anyone got one, new or used.
Bill w.
Re: Speedo.
June 26, 2019, 05:51:20 PM »
Sorry Bill afraid that is so rare now you may have to bite the bullet and pay DS a fortune, in his defence it is a relatively complicated casting with a lot of machining for a small sales quantity
Seabeowner
Re: Speedo.
June 26, 2019, 07:15:57 PM »
I have a spare that I was hanging on to but may sell. I,m away until Tuesday. PM me if interested.
1971 CB500K0 Candy Jade Green or Candy Gold
1973 CB500K1 Candy Ruby Red
1975 CB550F1 Shiny Orange
heliwilly
SOHC Member
Re: Speedo.
June 26, 2019, 10:35:58 PM »
Just checking another source, will let you know. Cheers Bill W.
heliwilly
SOHC Member
Re: Speedo.
Reply #10 on:
June 27, 2019, 07:25:26 AM »
Hi Seabeowner,
Just checked a second engine I am sorting. That has the tacho housing missing. How much for yours please. How do you want paying?
PM me details.
Bill W.
Speedo.
