Author Topic: Which Paint Stripper ?  (Read 2790 times)
« on: February 13, 2021, 09:58:18 PM »
My old tin of Nitromores circa 1995 has almost run out. Found this on e-bay but I don't believe all I read.
.https://www.ebay.co.uk/itm/Power-Strip-Best-Industrial-Strength-Heavy-Duty-Paint-Stripper-Remover-1Litre/252471247040?hash=item3ac87580c0:g:UpkAAOSwZZlbmN1c
What's the best old school alternative?
Offline allankelly1
« Reply #1 on: February 13, 2021, 10:01:18 PM »
Hi Ted
I got this off eBay
Burns your skin just like the original nitromors
Best wishes Al
Re: Which Paint Stripper ?
« Reply #2 on: February 13, 2021, 10:21:44 PM »
Paramose is the closest I have found to original Nitromors as it contains the same main active  ingredients ... i.e.  Methylene Chloride (Di-chloro Methane) and Formic acid  (you know .. the stuff in ant bites). Nasty stuff but proper paint stripper. They make  a thick and a thin version ... both seem to work fine...same strength just that one has a thickening agent in it so it doesn't run off the surface so easily after application.
https://www.ebay.co.uk/itm/265018626524
« Last Edit: February 14, 2021, 01:44:24 AM by AshimotoK0 »
Offline Charlie J
« Reply #3 on: February 14, 2021, 09:11:03 AM »
I recently used Power Strip Heavy Duty Paint Stripper. It's just as good as the old style Nitromors.
https://www.ebay.co.uk/itm/Power-Strip-Paint-Stripper-Remover-High-Strength-2-5L-Wood-Furniture-Restoration/262539148822
Offline eight0
« Reply #4 on: February 14, 2021, 10:04:36 AM »
+1 for Synstrip. It's nasty nasty stuff though. It Contains: Methylene Chloride (Dichloromethane - DCM) Methanol Phenol Formic Acid Acetic Acid and is only supposed to be used in industrial environments.
Which means it must be good.
« Reply #5 on: February 14, 2021, 10:18:44 AM »
Thanks for the suggestions folks.
The Dichloromethane sounds a nasty ingredient so I will need to heed the warnings not just about corrosion on skin but the fumes sounds quite damaging if inhaled !
« Last Edit: February 14, 2021, 03:32:55 PM by Macabethiele (Ted) »
« Reply #6 on: February 15, 2021, 07:50:13 AM »
Hi Ted
I got this off eBay
Best wishes Al
I second this stuff but use gloves and a mask. P.s. don't go near plastic with it  ;)
Offline adespin
« Reply #7 on: February 15, 2021, 02:10:05 PM »
I'll second Powerstrip, used it for two restorations, strong stuff.
1971 cb750 K1
