Author Topic: The rebirth of Lazarus  (Read 224507 times)
Re: The rebirth of Lazarus
« Reply #165 on: April 02, 2023, 10:35:06 PM »
Max made my SS wheel & engine spacers on my 500  plus the brake hub stay fitting. Very pleased with the quality.
Offline mickwinf
« Reply #166 on: April 02, 2023, 10:44:50 PM »
ah yes I did get some spacers off max but not the bolts. the one on the brake plate is a nos one.
Offline mickwinf
« Reply #167 on: April 12, 2023, 06:06:58 PM »
Just got the powder coating back and I am well pleased with it. The frame looks ace compared to before and  all the other bits look great too. So engine and frame now together and can start putting bits back on.
« Reply #168 on: April 12, 2023, 07:01:26 PM »
Looks to be a nice finish Mick but it also looks very thickly applied, especially in the close up of the back end. Any problems with fitting parts yet?
The engine bolts look to be made by Middletons Mick, is that correct?
« Last Edit: April 12, 2023, 07:04:19 PM by Oddjob »
« Reply #169 on: April 12, 2023, 08:17:19 PM »
That's looking great Mick. It's must be a nice feeling to be putting the bike back together.
« Reply #170 on: April 12, 2023, 08:32:52 PM »
Coming together now, Mick. Definitely worth the effort. It must be very satisfying considering what you were presented with.
« Last Edit: April 12, 2023, 09:22:51 PM by Sesman »
Offline mickwinf
« Reply #171 on: April 12, 2023, 08:44:38 PM »
I think they did 2 coats with rubbing down but not had any problems yet. Stainless bolts are from middletons as they do the range of sizes with correct threads and heads.
« Reply #172 on: April 12, 2023, 08:57:06 PM »
Looks a fraction better than when you got it
« Reply #173 on: April 12, 2023, 09:37:09 PM »
I like the really shiny black on frame finish, maybe some don't feel it's original enough but something as this one, brought back from near death,  is lucky to be getting such care and attention.  :)
Nice work all round.
« Reply #174 on: April 12, 2023, 09:37:52 PM »
I recognise the bolt heads on the Middleton bolts, he does 10 metric fine bolts with the correct 14mm heads as well. Oddly enough I found my stash today hiding in a box. I got the 4 for the engine hangers, 4 for the twin calipers and the 2 for the rear suspension lower bolts. The problem being I'm fitting Mazzocchi dampers and they don't fit as they are metric coarse. Might be able to reuse some of the old Middleton bolts from the early 80s that I was forced to fit in the engine as they didn't do 14mm headed bolts back then.
Offline mickwinf
« Reply #175 on: April 16, 2023, 12:43:42 PM »
Having a Potter with Lazarus, and thought you guys would like some before and after shots. Hope you notice the difference! Edit still having trouble with photos
« Reply #176 on: April 16, 2023, 12:47:41 PM »
Picture  does end up the right way when you click on it - looking good - nice rear fender.
Offline mickwinf
« Reply #177 on: April 16, 2023, 01:15:09 PM »
Hmm
Offline mickwinf
« Reply #178 on: April 16, 2023, 01:18:36 PM »
Try again
Offline mickwinf
« Reply #179 on: April 16, 2023, 01:19:22 PM »
Thanks Ted, it is a rechromed US spec.
