Author Topic: 550 F2 started!  (Read 345933 times)
Re: 550 F2 started!
« Reply #525 on: September 12, 2022, 12:52:42 AM »
Reasonable day today cleaning bits n bobs, getting prep sorted. I’ve been on and off it all day fitting in other jobs but pleased with progress. Timing tmrw eve
 if I get chance, heaps to sort before departure but getting there
Re: 550 F2 started!
« Reply #526 on: September 12, 2022, 12:53:12 AM »
Re: 550 F2 started!
« Reply #527 on: September 12, 2022, 12:58:09 AM »
Quick question in prep for wrestling on the cam sprocket…
I had a thin line on the points end of the cam on the 400, I don’t appear to have anything except this notch, I presume that’s the mark is it?
If so, do Ione up the bottom of the notch with the shite face of the top of my head? Would that be the correct way?
Just checking as I can’t find a ref just yet….
Ta
Online Oddjob
Re: 550 F2 started!
« Reply #528 on: September 12, 2022, 01:07:00 AM »
T mark on 1-4 on advance retard mechanism and notch level with head pointing forward
Re: 550 F2 started!
« Reply #529 on: September 12, 2022, 08:37:42 AM »
Middle of notch level with gasket surface in your pic cam needs to rotatebackwards probably 1 tooth on the sprocket
Re: 550 F2 started!
« Reply #530 on: September 12, 2022, 09:34:28 PM »
Theres no sprocket on it I just laidthe cam in before I locked up last night and noticed it as shown.
I realosed I should have spun it a bit for the shot but couldnt be bothered to go out again to take another . I havent seen this before so hence the question. I'd asumed that it should sit with the bottom of the notch level with the surface of the head.
Ive not got as far as the A/R mech, that was tonights job but just got home so I think thats torn it for 'ce soir'.
Cheers fellas, I'll set it up if I get a vahnce but realstically I dont think I'm going to get a chance before I leave.
Cheers ;)
Re: 550 F2 started!
« Reply #531 on: September 13, 2022, 07:57:31 AM »
Yes, that’s right Roo. Notch parallel to head. You probably won’t be able to get the chain on with the cam in that position though. The trick is to engage the cam wheel on the chain in a guesstimated location then locate one of the two cam bolts. A slow rotation will allow you to locate the 2nd bolt. Then check the the 1:4 timing position and cam slot. You will soon see if you have to step one tooth back or forward. Observe the manual carefully and make sure you start the process with the cam wheel, chain and cam as illustrated…it makes the difference.
« Last Edit: September 13, 2022, 08:00:32 AM by Sesman »
Re: 550 F2 started!
« Reply #532 on: September 13, 2022, 07:11:30 PM »
spot on Thanks Phil, thats spot on mate. ;) :)
Re: 550 F2 started!
« Reply #533 on: September 17, 2022, 06:18:04 PM »
Presents when got here!
Hondaman box for Jezza
Gear selector spacer thingy for Bryanto replace the one he lent me
And this little NOS cracker……get in
Re: 550 F2 started!
« Reply #534 on: September 17, 2022, 06:26:56 PM »
And here's your one that Trig has repaired 😁😁😁
Re: 550 F2 started!
« Reply #535 on: September 17, 2022, 06:29:18 PM »
Fantastic, Thanks the pair of you. Happy to have a spare now though and a few bust ones to have a go at when i get home if you n Trigg can help me out with a couple of those tangs also Julie as per email etc.
Well chuffed all round then............having a better week already ;D
Re: 550 F2 started!
« Reply #536 on: September 17, 2022, 06:33:56 PM »
What is that please….
Re: 550 F2 started!
« Reply #537 on: September 17, 2022, 06:44:53 PM »
Is it the neutral switch contact?
Re: 550 F2 started!
« Reply #538 on: September 17, 2022, 06:56:15 PM »
Yes Phil, that's correct.
Re: 550 F2 started!
« Reply #539 on: September 17, 2022, 07:31:14 PM »
Thank goodness. When Roo mentioned “gear selection” I nearly fainted wondering what I’d left out.
